Scott R's Avatar
Distributor question
I've been searching the archives for hours, and I must be missing something. I was testing certain aspects of my distributor and I found that I can pull the center shaft up by the rotor about 1/2" inch. If I'm reading some of the older threads correctly this means that I have excessive vertical shaft play?
Also what I perceive to be backlash in the shaft is also pretty sloppy... what to do?
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 10-30-2007, 09:49 AM
gtihop's Avatar
yup that's what you have. Just went through all that and rebuilt it. should have .004" up and down play- not very much. search some articles about rebuilding it- not too hard to do.
1983 911 SC
2015 Volks GTI
1991 Volks GTI
2011 Nissan Juke
1992 Nissan NX 2000
Old 10-30-2007, 10:38 AM
Scott R's Avatar
What I'm seeing is that the rebuild is easy, getting the parts on the other hand is not.
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 10-30-2007, 10:39 AM
I would rather be driving
jpnovak's Avatar
Does the rotor turn itself when you pull up the 1/2" If not, I suspect that your rotor mount on the centrifugal advance mechanism is loose. Pull off your rotor, pry out the piece of felt under the rotor and check the screw to see if it is tight. Tighten the screw and that should solve your problem. Don't forget to put some oil on the felt when you put it all back together. This keeps the advance mechanism lubricated.
Old 10-30-2007, 10:45 AM
Scott R's Avatar
Everything is loose, but I'll check that shortly and report back.
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 10-30-2007, 10:54 AM
Scott R's Avatar
OK, the screw behind the pad is tight, the entire shaft is moving, bottom to top.
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 10-30-2007, 01:29 PM
gtihop's Avatar
I used steel washers that I got from a local electric shop.Took a bit of trial and error to get the clearance right but it worked well. I bought the gear pin from the porsche dealer for 2.30 . Drilled out old pin was the easiest way to get gear off. The effort was woth it- cars runs really good now.
1983 911 SC
2015 Volks GTI
1991 Volks GTI
2011 Nissan Juke
1992 Nissan NX 2000
Old 10-30-2007, 01:52 PM
Scott R's Avatar
Well, isin't this interesting:
Ok, what exactly is missing?
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 10-30-2007, 02:14 PM
Scott R's Avatar
Oh man it gets worse, one spring was floating around inside the housing, the little tang that holds the spring is all bent to hell and a chunk is missing from the weight unit. DOES IT EVER END!
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 10-30-2007, 03:40 PM
gtihop's Avatar
Could be like mine- the PO had the springs reversed and the vac lines switched at the throttle body!
On the bottom-1 steel shim, 1 fiber shim and 1 steel shim. Inside I used all steel shims and added/subtracted to get the proper clearance. There are some really good pics of what the weights and springs look like- I'll try find them and send them.
Search dist thread under my name about a month ago, you'll see some members that posted really good rebuild procedures.
1983 911 SC
2015 Volks GTI
1991 Volks GTI
2011 Nissan Juke
1992 Nissan NX 2000
Old 10-30-2007, 03:45 PM
Scott R's Avatar
Thanks a ton for the pics! The spring has one end on the magnet, and the other on the base. The little plastic piece, tiny little butterfly looking thing is cracked, and the tabs are gone. So the spring just flew off at some point.
About the vertical play, I just pulled the drive gear off and I ended up with the exact amount of shims you stated above, now can you tell me where to add the additional shims when I put it back together? (barring that I can find a way to repair the spring retainer.
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 10-30-2007, 04:33 PM
gtihop's Avatar
put the shims inside the housing below the advance plate. put an approx amount of shims to take up the play, reinstall gear temporarily and measure endplay with a feeler guage. Add or subtract these shims to get the proper clearance. I used steel shims from an motor rebuilding shop. When you finally put drive gear on, make sure the new pin is installed and peen the ends over so it doesn't come out. This must be done or the pin and gear will come off= new engine!
as far as the spring retainer- try a tiny dab of expoxy to hold the end of the spring over the retainer or find a used one
1983 911 SC
2015 Volks GTI
1991 Volks GTI
2011 Nissan Juke
1992 Nissan NX 2000
Old 10-30-2007, 06:41 PM
Scott R's Avatar
I corrected the spring keeper by decreasing the eyelet of the spring, also not per a previous poster the springs were on the wrong sides, long vs. short, stupid PO.
I'm going to ask my mechanic for shims tomorrow, and thank you very, very much for the advice on where to install them.
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 10-30-2007, 07:01 PM
other holtjv pics
Distributor service (Clean and lube) real easy without removing the pinion gear!
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 10-30-2007, 08:43 PM
Scott R's Avatar
OK, was just finishing up the rebuild today, and I installed the new roll pin in gear. How do I insure that the roll pin stays in? Can I tack weld it? Maybe something else?
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 11-02-2007, 04:49 PM
gtihop's Avatar
what i did was flare the ends over with a punch and hammer. it sort of mushrooms each end so that it won't come out. easier with a person holding the dist and one person with the hammer/punch.
1983 911 SC
2015 Volks GTI
1991 Volks GTI
2011 Nissan Juke
1992 Nissan NX 2000
Old 11-02-2007, 07:11 PM
Scott R's Avatar
Thanks once again for the advice, I'll flare it in my shop press tomorrow.
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 11-02-2007, 08:01 PM
