First Engine Pull!
I pulled the engine and tranmission by myself for the first time. It wasn't nearly as bad as I thought it would be. I had one jack under the transmission and one jack under the engine with a 2x6. It was a little tricky maneuvering both jacks at once to slide it out but it all went off without a hitch. Now its time to replace my valve stem seals....
Scott http://forums.pelicanparts.com/uploa...1193800832.jpg http://forums.pelicanparts.com/uploa...1193800867.jpg |
| All times are GMT -8. The time now is 01:18 AM. |
