-   -   How many miles for break in (http://forums.pelicanparts.com/porsche-911-technical-forum/375005-how-many-miles-break.html)
johncmng 10-31-2007 01:51 PM
My newly rebuilt transmission is a little sticky. How many miles do I need to put on it before it's back to normal? Anything I should look out for?
John
3.2 Carrera
pozee 11-01-2007 03:13 AM
If by "sticky" you mean it feels "new" ....I would say 100 or so miles of normal driving. If "sticky" means grinding or not easily going into gear etc....you need to have it checked for a possible issue.
Scott R 11-01-2007 06:55 AM
I had no break in, worked perfectly from mile one.
84toy 11-01-2007 07:26 AM
Must have been old parts:D
I have found that when using new syncros and new shift sleeves that they shift "firm" for about 1000 miles.
I have also found that you can get them to shift very slick by following the post listed below. The idea is to get the the sharp sandpaper texture of the syncros worn in little faster. There may be those who think this procedure is nuts but many shops do a similar procedure before delivering the car. With the axles disconnected it does no harm. You can pack a 1000 miles of shifting in very quickly.
See http://forums.pelicanparts.com/porsche-911-technical-forum/358511-915-break.html
Good luck.
Scott R 11-01-2007 07:28 AM
See http://forums.pelicanparts.com/showthread.php?t=358511
Good luck.
No, everything new, very little was salvageable at all, including the bearings. Maybe my mechanic has a trick....
