[QUOTE=ischmitz;3605019]Bob,
The 22v zener diode is a protection against over-voltage spikes on the supply. It has nothing to do with the DC/DC converter. Z1 (82 volt) is what limits the DC/DC converter output voltage. However, I am confused. Let's get some answers: 1. Are you saying the one-spark without trigger behavior changed because you changed R1 to a good working one or because you changed the value of R1 t0 120Ohm? With an 120 R resiator as R1 the failure mode occurs at higher voltage and it is limiting the current. I assume this is not the problem. 2. Do you see T4 producing a spike that fires the SCR? If yes simly disconnect the gate on the SCR and repeat the test. I am trying to isolate whether your signal stage fires the SCR or whether it breaks down. Will do. T4 2N2905 Emitter disconnect from the gate of the SQR. When the failure occures the emitter shows this little egde on the scope. The spark started to show an intermittance. Also is this single-spark event happening at 20 volts or at 14 volts and is it depending on box temperature? With the 120 R resistor is came at 20V with the original 56R it can at 16V no trigger. Let me check if this failure is still there. Next, for the locking up with trigger signall can you measure the dV/dt rate for the SCR? See the scope picture as an example? In this case the anode was negative for 110uS. I have seen that time to be as short as 68uS in working boxes. So under temperature this is what challenges the SCR. http://forums.pelicanparts.com/uploa...1195928974.jpg Also, did you check the snubber? I changed the capacitor and the resistor. I have to reasseble it to see an improvement or not. By the way, even new old stock (NOS) is not an insurance for a good working part. This could well have been parts that did not meet one or several performance specs such as tq. If I were you and I wouldn't want to diagnose the problem but shotgun it I would drop in a suitable replacement SCR and check if this fixes the box. [ |
This is the output emitter of the 2N2905 at failure mode. Loren this is what I measure on the Gate of the SCR without a trigger. |
Ingo I change the SCR again and replaced it by an 2N6509.
The problem still occurs. The problem is still there. I ramp up the voaltage one spark. As you said I disconnect the Gate and also measured the base on T4. (2N2905) and Gate paraelle. At 15V no trigger http://forums.pelicanparts.com/uploa...1196005837.jpg Now with 16V no trigger. Suddenly I get pulses al over. Like a break through. http://forums.pelicanparts.com/uploa...1196005958.jpg When I trigger the box I see multiple trigger next each other. http://forums.pelicanparts.com/uploa...1196006044.jpg http://forums.pelicanparts.com/uploa...1196006095.jpg http://forums.pelicanparts.com/uploa...1196006156.jpg Any Id what can cause this ? Bob |
"Do you see T4 producing a spike that fires the SCR? If yes simly disconnect the gate on the SCR and repeat the test."
It's not a good testing procedure to leave the gate open, given the need to isolate the sporadic problem. The best approach is to just short the gate to the cathode. Then place a .01/600 capacitor accoss the anode to cathode. If the SCR still "fires" as the input voltage is increased, then the SCR is bad. |
The systems fires up without the Gate connected. So it defenitly get ignited over the Anode. I tried several different Thyristors. THE SCR is not the root cause. All of them get ignited over the anode without a trigger connected. What could be the reason that the SCR gets ignited over the Anode. I can measure 433Volt on Anode and I don't see any spikes or noises on the load capacitor. Bob |
When I ramp up the voltage see what happens. |
"It's not a good testing procedure to leave the gate open, given the need to
isolate the sporadic problem. The best approach is to just short the gate to the cathode. Then place a .01/600 capacitor accoss the anode to cathode. If the SCR still "fires" as the input voltage is increased, then the SCR is bad." Follow the above instructions. |
the symtoms you are describing are correct. Even without a gate & trigger connected CDI produces one spark and the DC/DC converter frequency goes up and the current rises to more than 3 amps. But it is not the thyristor which causes to go into avalanche mode. I tried 4 types of SCR now. T12N 800COB /T10N600COB / T6N600COB and 2N6509. I am 100% sure the problem is hidden somewhere else. But I have no ID where to look. When I disconnect the Anode I can ramp up to 18V and the DC/DC converter keeps it frequence. with the Anode connected I get one spark without the trigger . Any further ID. Till today I have to changes the 0.015mF & 6800nF capacitor. I need to order a replacement. But that, s not root cause. What is the reason that the DC/DC converter makes the SCR to go into avalanche mode.? Bob |
I tried 4 types of SCR now. T12N 800COB /T10N600COB / T6N600COB and 2N6509. I am 100% sure the problem is hidden somewhere else. thanks Bob |
Loren I did it as you said, and the SCR is not firing. Not even at 20V. I did it with & without trigger. Does it means the failure is been initiated through the gate? Bob |
"Does it means the failure is been initiated through the gate?"
Yes, but more tests are required. Next remove the .01 you added and do the test again, still with the gate shorted to the cathode. |
Hm, it seems you are finally starting to narrow down the reason for the failure. Without trying to jump to conclusions it looks like either noise on the gate or a bias prematurely fire the SCR. With the gate tied to ground you seem to be able to eliminate this.
I would guess that by removing the 0.01uF/600V over the SCR the result should stay the same. However, without data it's just another damn opinion. ;) So please do that test. Next you need to find out why the signal stage is noisy (AC) or leaky (DC). Loren (or anyone else), correct me if I am wrong but one should be able to monitor the output of the trigger signal stage (R14/R15) even when it is not hooked up to the gate of the SCR, right. Check if you see a bias (DC) or noise (AC) component when you raise the supply to where the SCR usually fired. |
Dear all & Ingo, Loren,
the second test with gate shorted to kathode without the capacitor showed no spark as well. I also measured a little 0.35V sawtooth signal at Gate with 15V supply just before the SCR ignited. Bob. |
However, where and under which conditions do you measure a sawtooth signal at the gate? Is this with everything connected and the gate not shortened to GND or with the gate shortened to GND and disconnected from the signal output stage? Please be a little more specific. Cheers, Ingo |
I measure this little sawtooth in normal usage, without the short from gate to kathode. No trigger. 15V Supply. Everything connected and the gate not shortened to GND |
...wait a second: Now that I am reading back through your posts I see this image showing capacitor C2 that filters the 6.8V from the Zener diode to be puking electrolytic fluid :eek: So it is a reasonable assumption that it's that either dead or has a least lost most of its capacitance.
That being the case the regulated 6.8V will be "dirty" (aka ripple) and WILL cause problems downstream. Please tell me it's not that simple and you have either changed that cap or at least verified the 6.8V supply to the signal stage on your scope....... |
No change either. I ordered new one and will replace it to be 100% sure. Bob |
but can it be that this material under the cap is conductive solid electrolyte. I cleaned it with a dremel and brush. final test wil follow with the 22mF. What is the Voltage Range according spec. 10 to 18V? I replaced the C2 capacitor against an 22mF with some litle improvement when I replaced it with and 100mF the break through came at 18.8V with an 220mF at 19.5V. Regards Bob |
Loren, Ingo I replaced C2 and have the CDI run hot. Same problem appeared.
First I see the current start to go up and down from 2.5A til 2.7A. Then I get this noise on the Gate. http://forums.pelicanparts.com/uploa...1196194006.jpg Then the frequenz goes up. The SQR goes into conductive. Thats what I see on the scope. http://forums.pelicanparts.com/uploa...1196194129.jpg Any Id what to do next. How about disconecting C4. My Scope is not able to the spike when the Thyristor is getting conductive. I only see this unsober spike. What is the root cause for this? Thanks Bob http://forums.pelicanparts.com/uploa...1196194596.jpg |
Disconnect the gate of the SCR and tie it to GND. Then check your signal stage for where the sawtooth comes from. Check the supply voltage (6.8volts), the Schmidt-Trigger, and the final output stage - something is oscillating.
Wow, that is a lot of mechanics for triggering the boxes. I needed something that runs indefinitely for long-term testing so I came up with a little 555 timer based trigger circuit on a bread board.
http://forums.pelicanparts.com/uploa...1196359619.jpg It works for both 3-pin and 6-pin boxes. With this design you can choose between a high speed around 6000 RPM and a low speed setting around 1000 RPM. It shouldn't take more than half an hour to put this together. If you want to get more sophisticated you could put another voltage devider and RLC network for pulse shaping onto the 6-pin output to closer simulate the real trigger signal of the 6-pin units. Any news on your testing? Ingo |
http://forums.pelicanparts.com/uploa...1196006095.jpg Dear All I do see multiple trigger on the Gate. Gate of the SCR is brigded to Kathode Is that normal. Regards Bob. |
That trigger you see I used in the past perfect. I use now a 2 Volt pp sinus signal. I also bought a function generator. It is still in the mail. Will have it soon. Regards bob bob |
Let me re-phrase what you are saying: You have the gate shorted to the cathode, in other words C6 is shorted. If that is the case you will not be able to see anything on the gate because it is tied to GND. I assume the latest scope traces shows the voltage at the anode of the SCR. When you raise the supply voltage to 16V and beyond you start to see spikes on the scope, correct? If my above description is correct there are only two possibilities at this point. Either the SCR breaks down electrically or you have an isolation problem. Inspect the mounting of the SCR closely. I don't remember what the last SCR is that you have swapped into your box. Was it the 2N6509? TO220 cases have the anode present on the cooling fin. The heat sink in the box is at GND. If you don't use the proper washers and isolators around the metal screw there will be arcing going on. It most likley happenes between the metal screw and the inside of the hole of the cooling fin. Look for the tell-tale black marks. Ingo |
The gate conection was open. SCR Gate & Kathode shortend. I meaured between R14 & R15. |
Ingo what output do you use? 2Vpp. When I use 2VPP sinus and I increase the volume from 8 to 14V I also increase the noise signal ratio and the schmitt trigger gets false pulses. When I use a higher input signal the for exmple 6Vpp the box works fine. So what is the values to test the box. I read in the bosch bible that the output on the magnetic pickup varies. so what is the low & what is the highest values. bob |
bob |
With all respect Loren with a 1.0V peak to peak I'll get so much noise overlaying from the cuircut. Are you sure this is the value to go with. Bob |
I have recently be given to repair a 6 pin CDI with a similar problem under temp.
A lock up occurred only at high temp and at high rpm. At first try on my bench I was unable to reproduce the phenomenon, even after half an hour of 8000 rpm at 14.4 V. Finally I was able to reproduce the lock up by switching just for a second my generator to the equivalent of 80000 rpm ! The SCR was an original AEG T10N 600. The phenomenon was identical with either a 16RIA80 or with a 2N692 (extracted of my drawer). As the frequency of the converter increased to about 10 kHz when in lock up condition, I suspected a Tq problem, so I got rid of the problem with a BTW30-800 from ST Microelectronics, which is with a TO 48 case and has a Tq specified at only 12 µs max ! Unfortunately it is rather expensive since I got it from my electronics parts distributor for 20 euros (about 30 $) each ! I do not know if it is easily available in the USA since ST Microelectronics is an European semiconductor company. I can provide the full specs of this SCR if somebody here is interested. |
JMChrist,
now Warren is missing. Do you have the chance to monitor the voltage on the load capacitor I assume what could be your problem. Can you monitor the voltage and you will see that your signal shows a lock up of swichting. http://forums.pelicanparts.com/uploa...1215112176.gif I figured out that the 2N6905 performes better that the OEM Thyristor. See my plotshttp://forums.pelicanparts.com/uploa...1215111746.gif and now the noises and low level caused by the power consumtion. http://forums.pelicanparts.com/uploa...1215111891.gif Good luck would change the THYristor to 2N6905 and redo your bench test. bob |
That what I assume what could happen at high temp.
http://forums.pelicanparts.com/uploa...1215112547.jpg |
HKZ Bob
What are the traces in the scope photos? I think the first one is the high voltage cap but what are the others? http://forums.pelicanparts.com/uploa...1193934881.jpg |
Tq and lock up
HKZ Bob
You wrote : > now Warren is missing.< Unfortunately. Yes I know. > Good luck would change the THYristor to 2N6905 and redo your bench test.< I agree that a 2N6905 would also solve the problem since it is specified with a Tq of 15 µs typical. But the TO 220 case of the 2N6905 is much less practical to install than a TO 48 one. Since my lock up problem has been solved with a BTW 30-800 which has the same TO 48 case as the original SCR from AEG and has a Tq of 12 µs max, I have no intention to put instead a 2N6905 even though it is cheaper... |
Guys - the issue is most likely NOT the SCR. I agree that putting in an SCR with lower tq will help but you are band-aiding the real problem.
The main capacitor becomes part-ohmic with elevated temperatures. This increases the load on the DC-DC converter producing even more heat from the 2n3055. Heat degrades the SCR performance (tq). And it leads to the capactor to become even more ohmic. It's a typical run-away situation. Eventually the SCR is unable switch off and the box locks up. Even devices with tq=15 usec will lock up eventually. Ask me how I know. Change the capactor C8 and your problems will magically disappear, even at 8k RPM on a hot summer day. Ingo |
Thanks Ingo,
changing C8 was one of the actions I done when trying to solve the lock up at extreme conditions. It was unsuccessful. My feeling is that the transformer of the converter in this particular box could be at the lower limit (I do not know what it is) in term of inductance This could explain that its operating frequency seems to be higher than usual. I measured 3.72 kHz when idle at 14 V. In another (operating) box I found 3.35 kHz. I presume that, mpore or less, higher is the frequency, shorter is the time allowed to the SCR to return to the open state. |
I don't think the frequency of the DC/DC converter affects the SCR's ability to comutate. You can see each swing of the half-wave rectifier on the rising voltage at the anode of the SCR as a little riple. I have seen anything between 3 and 4 kHz in different boxes and it did not seem to affect the stability of a given box.
If C8 wasn't the issue how about the snubber across the SCR. It is to limit dV/dt which is the other factor that can make an SCR to turn on. If dV/dt becomes too large the junction capacitance can trigger the SCR with no signal to the gate. Ingo |
The only major component that I was not able to check or to change is the transformer. May be it is the real culprit, with an inductance that I found a little too low by comparison with another box (operating correctly). Now that the box is correctly operating with a BTX30-800 I am not really motivated to try to change the transformer. jmc |
The other shots are on the Gate of the SCR. bob |
Bob |
HKZ Bob wrote :
> JMC What are you paying for an BTW30 -800 < As I said earlier, I paid 20 euros (about 30 $) a piece for the BTW30-800. jmc. |
| All times are GMT -8. The time now is 01:58 AM. |
