jonbot's Avatar
Green struts and shock absorbers
I was under the car today, checking out my failed clutch problem, and took a look at the struts. Turns out they're green in the front, and the absorbers in the back are green. From what I understand, this means the struts are bilsteins, is that correct?
Old 11-10-2007, 06:49 PM
You are correct. Bilsteins handle pretty well so you have a good setup on there.
Old 11-10-2007, 06:52 PM
