atr911
Guest
Posts: n/a
Dissapointed or Excited?
I finally got all the cylinders and they appear good. What I was hopping to find out from you guys with experiece is this;
In removing the top end I found two broken head studs (cylinder #6 exhaust and cylinder #1 intake) and two collided or burned exhaust valves (cylinder #2 and 1 cylinder #6). Should I be dissapointed because these will likely cost me (much?) more money than expected or should I be excited because of the MUCH better performance I will see when the job is done.
Keep in mind that this is the only 911 I have ever drived and I have only driven it with these engine problems.
I'm just curious as to what I'm up against here with these screwed valves.
Adam Roseneck
btw... I may be wrong about the cylinder #'s but they are close, just too tired to check right now.
1978 911SC 3.0
roseneck@cyberbeach.net
Old 02-17-2001, 01:35 PM
BRAINIAC
Guest
Posts: n/a
Neither, you should be embarrassed that you didn't have a proper buyers inspection done prior to purchase. Seriously though, you should be excited that in the end you'll have peace of mind and much better performance than before. And an engine that likely will outlive the rest of your car, judging by your driving record. (Oooh, that was a cheap shot. Sorry.) Just remember that you are learning and getting a lifetime of memories out of this. Many people pay big bucks to get this kind of education and you're getting that part for free! Always look at the positives. Life is too short to focus on regret.
Tyson Schmidt
72 911 Cabriolet
Old 02-17-2001, 01:52 PM
atr911
Guest
Posts: n/a
Ouch Tyson, that one hurt. Maybe next time you could just rip my nuts right off instead of just booting them a few time (twice if I read correctly).
I tend to be fairly positive so I'm also looking at this as a learning expericene. You are wrong about free though, this is going to cost me an arm and a leg. I have this gene that just doesn't allow me to do things unless I go all out. Ah well, what can ya do. I'm going to put some ice on my crotch before it swells and gets even bigger.
If the rest of you could please aim your cheap shots above the waist that would be great...
Just playin'
Adam Roseneck
Old 02-17-2001, 02:44 PM
rstoll
Guest
Posts: n/a
Adam, wasn't it fun to drive with 2 burned valves and pulled headstuds???? Just wait!!
Robert Stoll
83 SC
83 944
Old 02-17-2001, 02:58 PM
atr911
Guest
Posts: n/a
Yeah, the car went like snot even with all those problems, can't wait till she's fixed up. This probably explains the poor acceleration below about 3000 rmp, especially on take off. I was probably running 30 psi on those two cylinders.
The anger is brewing inside me again, I hope I never see that Guy or the Mechanic again... then again, I hope I do....
Adam Roseneck
1978 911SC 3.0
Old 02-17-2001, 03:40 PM
Jdub
Guest
Posts: n/a
You should be excited! I am continuing to drive a car that, unless a valve adj. and Techron runs have cleaned it up, is running 15% leakdown in one cylinder. Can you imagine what I will find when I finally get around to what you are doing...
In all events, when you complete this one, and get that sucker fired up, you'll know it was done right and that you saw to that yourself.
Jw
Old 02-18-2001, 10:29 AM
BRAINIAC
Guest
Posts: n/a
Well Adam, you passed the humor test. You are now an official board member. Unless Kurt B. wants to take a few shots at you. He's merciless!
Just tell yourself that this is an excuse to do the mods you would have done soon enough anyway. Which I'm sure is true, right? Fun is never cheap. At least you don't have a coke habit. That would be more expensive and you'd have literally nothing to show for it.
If you hadn't wrecked, it wouldn't have been long before you'd be dreaming of more power. Now you can get it and sympathy from friends and family at the same time. No flack for disassebling a perfectly running engine. I'd say it's a blessing in disguise!
Oh, and about the cheap shots. At least I didn't make any jokes about your name, my crimson throated friend. (Go ahead and take a shot at mine. With my name, I'm WIDE open)
Tyson Schmidt
72 911 Cabriolet
Old 02-18-2001, 01:12 PM
atr911
Guest
Posts: n/a
Thanks for the official greeting into the club. I can take it, I hear all about it from my co-workers and friends from school, it goes something like this:
"Hey Porsche boy, watch out for those guard rails on the way home eh!"
My skin is thick, plus, I can't wait to blow by them when this puppy is finnished. I'll leave your name alone Tyson, that would be too easy...
Adam Roseneck
1978 911SC 3.0
Old 02-18-2001, 07:03 PM
