-   -   Installing Front Cooler w/911 Gearbox- A Little Trouble (http://forums.pelicanparts.com/porsche-911-technical-forum/375901-installing-front-cooler-w-911-gearbox-little-trouble.html)
304065 07-28-2008 06:50 AM
Joe, it goes under the gearbox, not over it, I would think you could just remove the port heat exchanger. Don't take any shortcuts with the nuts-- heat them until they glow cherry red with an oxy-acteylene torch and remove with a 13mm swivel socket. (or 12mm if someone has used those nuts).
crashr 07-28-2008 07:20 AM
Hi Scott,
Where did you get those rubber coated clamps? Also did you just use sheetmetal screws to attache the clamps to the car?
joetiii 07-28-2008 07:23 AM
Thanx John,
I thought I had read about a special tool to remove the HE, but a 13mm will do? Good to know. ;)
304065 07-28-2008 07:29 AM
Actually, I mean a 13mm "swivel socket" which isn't in everyone's toolbox- this is for the hex nuts on the HEs. The other tool you need removes the barrel nuts, a conventional socket won't fit. I definitely recommend using the HE removal tool on the barrel nuts.
