davis911s
Guest
Posts: n/a
Flywheel lock, FIT 2.7????
Anyone know if the flywheel locks that you can order will fit a 2.7, or would I be wasting my time?
Shawn
Old 02-19-2001, 12:53 AM
s77911
Guest
Posts: n/a
I used a flat piece of bar stock drilled a hole large enough for the tranmission stud. Then a hole the same size as one on the clutch mounting screws. this worked great.
hope it helps. Worked on both the 2.7 and 3.0 liter motors.
Skip 77 911 3.0
Old 02-19-2001, 05:20 AM
Early_S_Man
Guest
Posts: n/a
Shawn,
The problem with the flywheel locks is not the size of the engine, but the fact that they are only intended to work with those Porsche-designed engine stands that run over US$300!
Angle iron, bar stock, or even a double-box-end wrench can be bolted to a pressure-plate bolt hole on the flywheel and one of the engine studs with large washers!
Warren Hall
1973 911S Targa
Old 02-19-2001, 09:01 AM
davis911s
Guest
Posts: n/a
Thank you guys, again I don't know where I would be without this board
Shawn
Old 02-19-2001, 09:30 AM
