i am building a 73RSR and looking to get some good ideas for what to do with thw wiring so if any have any pic it would be great thanksWavy
![]() ![]() ![]() Smil eWavy![]() ![]() ![]()
iroc wing
anyone looking for one of these
i guess you're using factory wiring?
I'd clean all connections with white vinegar, rinse with water, dry them, then apply dielectric on all connectors. I'd assume ignition switch is same when new so I'd install a new one. I'd also install headlight relays and a fuse on the dash light circuit.. and a new turn signal/hi-low beam switch. The yellow starter solenoid wire from the ignition switch is around 12g from factory. It's old and weak so I'd install a new 10g yellow. If car is stripped out like yours I'd also install a new main starter wire of a larger diameter gage using welding wire. new cabin light switches in door jams.
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
the first issue
now i have trying to do the same as fred cook with the fusebox and follow his instructions, but PO had put some wires differently, so now is there some confusion, any good ideas, f.ex i have two black wires that i can find out of where to put............
![]() [img] |
pictures of the mess
puhaaaaaaaaaaaaaa
