Spark Plug Wire Brackets...
Howdy,
I wanted to put back the original spark plug wire retainer brackets on my 3.2 engine. My fan housing has two 6 mm holes and one 8 mm hole on the left side. But the fan shroud only has one 6 mm hole and the larger 8 mm hole. See the picture. Can you tell me why I don't have the normal two 6 mm holes in the fan shroud for the spark plug wire brackets? Thanks, http://forums.pelicanparts.com/uploa...1194446633.jpg |
| All times are GMT -8. The time now is 04:31 AM. |
