-   -   Setting Webers - Off Idle problem (http://forums.pelicanparts.com/porsche-911-technical-forum/376170-setting-webers-off-idle-problem.html)
GotaT 11-07-2007 02:59 PM
My weber 40ida's are having a difficult time coming off of Idle when accelerating.. Any quick adj..
I have the Air screws turned all the way in and the Mixture screws 2 turns out.
I have them set for E spec cams.
jpnovak 11-07-2007 03:39 PM
First, have you balanced the throats with the air bleed screws and linkage? Do this first with a synchrometer. Afterwards, if you still have the problem do they:
1 - pick up then bog down or
2: just stumble
1 means your accelerator pumps are dumping too much fuel and the engine goes way too rich.
2 means they are likely not dumping enough fuel and the engine goes lean.
Look down the throats and make sure that all the accel pumps are giving fuel.
Shoepop 11-07-2007 04:46 PM
To add make sure you have no more than 3-3.5 PSI fuel pressure going to the carbs.
Alan L 11-07-2007 05:37 PM
The above replies are all good, but really need more info. Could be a host of things.
Do they cough and then come to life? Having the air screws turned right in sounds odd. My initial thought would be an air leak which means the mixture is disproportionately lean at low load/openings. I had this issue with a set of Webers once - not that it is peculiar to Webers. I found a manifold leak after hours of blaming the carbs/timing etc. If they have been running good previously, what have you changed, since the settings are largely fixed.
Alan
jclotz 11-07-2007 06:28 PM
Make sure the throttle linkages are properly adjusted. Use the hand throttle to get the speed to 3K and check the right to left airflow with a synchrometer. It may be balanced right/left at idle, but changes once off the idle stop screws.
RoninLB 11-08-2007 12:07 PM
initial timing affects my take off.
and
http://forums.pelicanparts.com/uploa...1194552445.jpg
http://forums.pelicanparts.com/uploa...1194552464.jpg
gigem75 11-08-2007 12:50 PM
try this
http://forums.pelicanparts.com/911-engine-rebuilding-forum/239742-71-t-still-backfires.html
scroll down to weber set up....
I had and I say had the plastic meter from pelican. It became a great baby rattle when the throat it was on spit back.
I got the old metal style off ebay for 20 bucks
GotaT 11-08-2007 02:00 PM
Thanks for the posts.. still adjusting everything..
