-   -   Noise in front end of car (http://forums.pelicanparts.com/porsche-911-technical-forum/376230-noise-front-end-car.html)
david63 11-07-2007 07:56 PM
I have a 1989 Carrera, there is a noise in the front end (sort of a squealing) that has gotten a little worse in the last week or so. I know it is not the front wheel bearings (I replaced them because I thought that was the problem, no change). The noise goes away if I touch the brakes. Probably a hint, could it be a sticking brake piston in the caliper not letting the pad come all the way off the rotor? Any help out there??
Pipo 11-25-2007 10:45 AM
I was about to post the same question. My 86 Carrera is doing the same; it feels as is one of the pads is touching. I checked them and do not look worn out, my guest if one of the retaining brake pad clips. However, I did not pulled them, if the pad material is cracked (must remove to see) that might be casing the problem.
Por_sha911 11-25-2007 11:34 AM
Either a stuck caliper or you have some foreign substance in between the pads and the rotor (on a typical car, I'd say you are down to the rivets on your pads). How many miles since your last brake job? Can you pull a wheel and check things out?
stlrj 11-25-2007 12:25 PM
On my car it was the A arm bolts that broke off the welded inserts in the pan:
http://forums.pelicanparts.com/porsche-911-technical-forum/352988-chirping-sounds-driving-me-nuts.html?highlight=front+arm+bolts
Por_sha911 11-25-2007 12:40 PM
Joe, did yours stop making the noise when you touched the brakes or was it just at low speeds...?
Trotskyite 11-25-2007 12:45 PM
Same problem, mine goes away when I touch the brake pedal. I have about 50 other squeeks and rattles to track down after this one :)
DCinVA 11-25-2007 02:09 PM
+1 on the calipers. Buy a kit and rebuild them. This is a very common problem.
