-   -   Clutch pedal return spring question (http://forums.pelicanparts.com/porsche-911-technical-forum/376307-clutch-pedal-return-spring-question.html)
oregonmon 11-08-2007 09:44 AM
How do I replace the clutch pedal spring? THe old one is broken and out, simply tried to push clutch to floor and hook it to the two mounting points but no go. Do I have to remove the pedal cluster? If so how big a job is that?
Thanks.
http://forums.pelicanparts.com/uploa...1194543843.jpg
mm86911 11-08-2007 09:47 AM
Not a fun job. I used some steel cable to stretch the spring over the shaft. Wear thick leather gloves and eye/face protection. Maybe someone else has a trick?
oregonmon 11-08-2007 10:15 AM
Oh great. Not another "not a fun job". I just did the clutch cable and ran into a couple hiccups with what I thought was going to be simple.
You mean you hooked the spring to the back shaft and then pull the hell out of it to bring it to the pedal shaft. Wow, you must be BUFF!
Superman 11-08-2007 10:52 AM
There has to be a way to use a prying tool for leverage. Indeed, a big herky example of one of those brake spring plier thingies would be the ideal tool.
Jim Sims 11-08-2007 11:50 AM
Tools help but a fair amount of strength is still required to do this task in situ. I used a hardwood dowel inserted into the free hooked end of the spring while my wife depressed the pedal for me. Using the dowel I caught the end of the hook onto the pedal cluster rod, removed the dowel and then used a soft faced hammer to tap the hooked end fully into place. Took a few tries before I got all the "actions" just right.
vash 11-08-2007 11:50 AM
i use the exact tool. slamdunk. i have done it in the car and out.
yelcab1 11-08-2007 11:53 AM
The tool looks like a brake spring attach tool, no surprise, same concept. Some modification may be required. your mileage may vary.
Or, big muscles.
Walter_Middie 11-08-2007 12:04 PM
There is a thread where someone stuffed quarters in the coils to expand the spring - then it just slips on and you remove the quarters. It worked great for me.
Here's a thread that might help:
http://forums.pelicanparts.com/showthread.php?t=159061&highlight=clutch+pedal+ret urn+spring
john walker's workshop 11-08-2007 01:23 PM
jeeze, i keep telling how to do this real easy like and noboby remembers. get one of these amerikan kar brake spring tools at the cheapo parts store and cut it off so it clears the wheel well hump when it's pulled back. hook the spring on the front cluster knob, slip the rear end of the spring over the tool shank, hook the tool over the pedal knob, pull back, allowing the spring to slide over the shank and onto the pedal knob. takes 2 minutes. http://forums.pelicanparts.com/uploa...1194556938.jpg
boyt911sc 11-08-2007 02:23 PM
Clutch Pedal Spring Installation........
Oregonmon,
You could either install the spring with pedal cluster in the car (very difficult) or remove the pedal cluster unit and work on the bench. I opted to remove the pedal cluster assembly.
Step one: Dismount pedal cluster from car and secure the unit in a vise as shown. http://forums.pelicanparts.com/uploa...1194559371.jpg
Step two: Hook up the small end of the spring.
http://forums.pelicanparts.com/uploa...1194559403.jpg
Step three: Line up the bigger end.
http://forums.pelicanparts.com/uploa...1194559448.jpg
Step four: Fabricate a strong wire loop using coat hanger wire to stretch the spring.
http://forums.pelicanparts.com/uploa...1194559491.jpg
Step five: Pedal spring installed.
http://forums.pelicanparts.com/uploa...1194559524.jpg
Once you have the wire loop fabricated, it takes only seconds to install the spring in place. Hope the pictures help you do the job. Good luck.
Tony
holtjv 11-08-2007 02:48 PM
packing the spring with big washers was easiest for me. spread it apart, insert washers, put on the pedal, remove washers with needle nose pliers. took 10 minutes max.
azasadny 11-08-2007 02:50 PM
Good thread. I never could get that damn spring back on, so I'm removing the pedal cluster to rebuild it this winter and I'll replace the spring then.
oregonmon 11-08-2007 04:38 PM
Thanks guys for the replies. I like the quarters/big washers trick. Seems very creative and pretty easy.
Thank again for your time, maybe try it tonight.
