Matt
mhoffman's Avatar
M&K Mufflers Rock!
Just installed 1 in 1 out stainless muffler in place of the stock unit on my '88 Carerra- FABULOUS!! Great sound compared to stock, and yes, it does look great!
The mounting hardware is the same quality as the muffler, so hopefully if ever needs to be replaced the pain in the arse removing the original stuff won't be an issue!
Way to go Bill!!
Matt
Old 11-09-2007, 10:33 AM
DB_NC_95C2's Avatar
I'll 2nd how happy I am with M&K, although I did the 2-to-1 when I went with SSI heat exchangers, I LOVE the sound (and after being at Rennsport all weekend it was nice to come
home to hear my car sound like a 911 should)
'95 Porsche 993 Carrera, DACH-X, DACH-R, PSS10,RS Speedlines,RS StrutBrace, GT3TEK 993RS Aero
'06 Mini Cooper (O.Z,MTH, Milltek, M7)
http://www.hakkinen.com/spain99-mh1st-easy.mp3
Old 11-09-2007, 10:43 AM
East Coast R Gruppe
mike monde's Avatar
Looking to install SSI's on my 1983SC, what M&K do I go with?
2 in 1 out or 1 in 1 out?
SSI's change what I would use?
Can anyone tell me the what is the difference and why one over the other?
Thanks,
OGRP3
RGRPNE
Old 11-09-2007, 12:32 PM
jstgermaine's Avatar
SSIs = 2 in 1 out
Stock exchangers = 1 in 1 out
Ditto on the M&K cans....you should hear them on my 996!
'99 996~LSD~VE Wheels~H&R Cup Kit~Aero~Recaro~X51~M&K~GT3 Roll Bar
'77 911 ~ very modern running gear ~
Gruppe B...the Midwest motorsports playground
Old 11-09-2007, 12:35 PM
DB_NC_95C2's Avatar
there's also the option when using SSIs of 2-in-2-out M&K and I thought about it. Apparently it's just a touch louder with the 2nd outlet, but I didn't care to go with the 2-out because of having to cut the right rear valance for the 2nd exhaust outlet. I wanted to keep the stock look, but M&K is so light and sounds so great one or two outlets.
I'll agree with Mike below, best performance/sound/driveability upgrade you can make. The SC now has much better throttle response, and it WANTS to rev, really woke up the car and probably wakes up the neighbors ;-)
I would think it's on a par with a stock Carrera with no modifications although I've not driven one to feel the difference.
Old 11-09-2007, 02:29 PM
Mike:
Stock configuration for an SC is heat exchangers into a cat into the muffler. 1 in and 1 out
when you convert to SSIs you dump all of that stuff and the SSIs become your heat exchangers and they connect directly to the muffler . It becomes 2 in and either 1 or 2 muffler outlets. Both sound great > but for me I chose the 2 in and 1 out.
With the 1 out > no cutting the rear valance >and the sound is still great.
My opinion > the SSI and M&K upgrade is the best bang fo rthe performance buck there is
Kim Langley
2012 Carrera / 991.1
80 911SC
97 C230
73 BMW 2002Tii
Old 11-09-2007, 02:40 PM
2 out is quite a bit louder, more resonance. FWIW
Old 11-09-2007, 03:00 PM
scottb's Avatar
Matt: Do you have a catalytic converter on your car? If so, how would you describe the sound of the M&K compared to stock?
Scott
1984 Targa
Old 11-09-2007, 03:12 PM
