jasonmx5's Avatar
AutoX/DE Seat Recommendations
I'm looking for seat recommendations. I currently have sports seats and I'm looking for an equivalent that will accommodate a 5 point harness for AutoX and DE. I want to still have the ability to slide and adjust the seat back angle. Suggestions? Please post pictures of suggestions if available.
Thanks in advance!
P.S. I'm preserving the original seats and interior in case I ever want to return the car to factory original.
"Making things easy is hard work"
My current stable: 1991 Carrera 4 Cabriolet, 1992 Mazda Miata, 2004 Lexus RX 330, 1994 F150 4x4 Supercab
Also rans: 1977 Carrera 3.0 (traded for C4 Cab.), 1983 944 (project car - sold)
Old 11-10-2007, 08:13 AM
be sure to check the installed height.... you want to fit with helmet on....
also double check that the hole for the 5th belt is far enough forward to not cause you to sing high notes.... I got a set of Recaros, forget the model just now and they are 1000% better than stock standard seats... they sit lower which is good and are much lighter... no electric motors/etc.
Also plan how you are going to use or change back and forth between street belts (3 point) and 5 or 6 point. The 1989 3.2 cars have the belt inside attach point moving with the seat.. so I had to invent a whole bracket system and it was a huge PITA. I've since taken everything back out.... the combination of the better holding of the Recaros and standard belts do OK but certainly not great..
Old 11-10-2007, 04:33 PM
