What kind of bit do I need?
What kind of bit does this require and where can I get one? The star bits I have are either too large or too small and I don't want to strip them out, they already look pretty messed up.
Kirkhttp://forums.pelicanparts.com/uploa...1194816210.jpg |
That should read "do I need" not "d I need";)
Most call it a triple square bit, it has 12 points. Not sure what size you need.
Door Striker Tool
Eck,
I have this tool for years and don't know what's it is called. You need an 8 mm tool to remove the securing bolts for 911 door striker. Good luck. http://forums.pelicanparts.com/uploa...1194819704.jpg |
What you need is a Spline bit (AKA triple square as mentioned by equality) :
If you can't get from Sears then you can find here from $2.50... http://www.lara.com/cgi-bin/store/commerce.cgi?keywords=bt-spl As boyt911sc states you want 8mm (AKA M8 or #8) |
triple square
avoid asking for a 'spline' as you might get a Bristol Spline - which won't work properly (or if you're lucky won't fit in there at all). It is some British thing with more meat near the center. |
An hand impact driver and BFH will also assist in removing these stubborn fasteners.
Sherwood |
Here is the tool I'm thinking of. Used for VW/Audi...described as a Spline tip driver for door lock assemblies. http://i8.ebayimg.com/07/i/000/b8/34/8fd8_1.JPG |
I only mention this tool as a friend has both the driver and similar bit. |
as mentioned, a 12-point tool AND a product called ' screw grab'. google it, it's awesome stuff. it's like little tiny chunks of carbide in a sticky goo. really makes a good grip between your tool and the fastener.
http://www.frentzandsons.com/eshop/catalog/147.htm |
Oddly enough, that tool showed up in a couple of the later 3.2 tool kits I have. Not sure where else it is used on the car though.
| All times are GMT -8. The time now is 10:26 PM. |
