-   -   Dropping Motor, what's needed? (http://forums.pelicanparts.com/porsche-911-technical-forum/377646-dropping-motor-whats-needed.html)
Thrlls 11-15-2007 04:42 PM
I'll be dropping my motor to install a new clutch, light flywheel, & headers. I also have a SW chip to install once the exhaust is in. Looking at the bolts...I hope they don't break during removal. I plan on doing this after my return from B.A.'s class in December. I hope to meet some of you there!
Question 1:
What other items would be best to change/inspect at this time?
The motor currently has 95k miles on it, but I'm not sure what the PO changed.
If I could, I would overhaul the top end, but I don't want to down the car for a long period of time just yet. I just got the car about 2 months, and would like to enjoy driving it more first.
There's nothing wrong with the car currently...no smoke, rough idle, hard starting etc. so I'm not too concern about a rebuild at this time.
Question 2:
For those of you that have a light flywheel, what are the pros & cons you have experienced?
Mahalo! SmileWavy
yelcab1 11-15-2007 06:06 PM
1/4 inch ratchet and extensions
3/8 inch ratchet and extensions
1/2 inch ratchet and extensions
10mm socket
12mm socket
13mm socket
17mm socket
19 mm socket
22mm socket
6mm allen socket
long 8mm allen socket,
short 8mm allen socket
10mm allen socket with a ball end
12 point tripple square socket for the flywheel (10 or 12mm I forget)
10mm wrench
12mm wrench
13mm wreches of different size, configurations, bends,
15mm wrench
17mm wrech
19mm wrench
32mm wrench or an oil line wrench
small med and large torque wrenches
0.1mm feeler guage
small / med / large flat screw drivers
small / med / large philips screw drivers
oil seal picker
circlip pliers
hammer and a piece of wood
gasket set
oil and filters
jack stands
2 jacks
2 small furniture dollies
one engine stand with engine yolk (optional if no engine work is planned)
one engine lift or 4 large neighbors (optional if no engine work is planned0
transmission oil and 17mm allen socket if oil changed is planned
one bag of 50 rags
That is the minimum list required !!!
Life is easier if you have air compressor, impact gun, impact sockets, a set of 39 piece Sears tap and die set, various picks, magnets.
Axiom 11-15-2007 06:21 PM
CV Joint boots
Fuel lines
Shocks
Flexible brake lines
Brake pads
Oil lines ( right side, I've seen them collapsed some times)
For starters, once your get the view under, you may see other things.
iamchappy 11-15-2007 07:01 PM
Beer
EarlyPorsche 11-15-2007 08:37 PM
I really hated the light flywheel. Make sure you know what you are getting yourself into with that. The engines idle get rough so you may have to raise it and you lose all low end grunt. That loss of torque sucks with an engine that is already terrible on the low end. Be very sure that you plan to use the engine at high RPM's on anything more than a slight hill.
Thrlls 11-15-2007 11:41 PM
:D :D :D
Okay wise guys...I got all of the above except the beer! :p
Now that I know what tools I need, what should I be doing with these tools?
Should I be concerned with fuel lines/filters? Are these item problematical? Any hard to get to parts that should be changed while the motor is out?
EarlyPorsche - Thanks for the feedback, I usually shift around 4k - 4.5k, as that is my cruising rpm. I figured if my bimmer can handle that my Porsche should.
How is the acceleration?
What about NVH?
Thank you everyone for info. I know it took a lot to type up the list of tools and it did serve as a check list for me.
PS....One last major question...what brand/kind of beer?
iamchappy 11-16-2007 06:01 AM
Beer choice is up to you, if I made a suggestion this thread may never end...
Dont minimize beer for this undertaking it is very important and vital.
Axiom 11-16-2007 06:35 AM
Then I'll do it. CORONA
DaddyGlenn 11-16-2007 06:44 AM
While your in there:
Throw out bearing and TO bearing fork gaskets
Oil pressure switch (before it goes bad!)
Replace oil lines and vacuum hoses
Adjust valves (replace valve cover gaskets with silicone type)
Plug wires
Plugs
Change the Tranny fluid
Replace clutch cable
Clean injectors
Replace injector sleeves and gaskets
Engine bay gaskets
Re-build distributor
Re-paint the engine bay
Remove the tin and shroud and clean out the cylinder fins
Powder coat engine tin and valve covers
Powder coat fan and housing
Replace engine tin screws with shinny new ones
That is all I can think of now that would be on my list. Your list may vary and can easily get longer. I would at least do the first four.
In fact, now that I think some more, since you will have all that room to work, you might as well disassemble the rear suspension and freshen all the bushings, wheel bearings, struts........ :D
yelcab1 11-16-2007 07:03 AM
[QUOTE=yelcab1;3590899]
1/4 inch ratchet and extensions (for all 8mm or smaller fasteners)
3/8 inch ratchet and extensions (for all mid size fasteners)
1/2 inch ratchet and extensions (for larger ones, like engine mounts)
10mm socket (above)
12mm socket (the only time needed is for the hollow tensioner bolts)
13mm socket (90% of the time)
17mm socket (almost never)
19 mm socket (engine mounts)
22mm socket (turning the engine fan)
6mm allen socket (CV bolts, fan shroud)
long 8mm allen socket, (Exhaust bolts)
short 8mm allen socket (intake manifold)
10mm allen socket with a ball end (starter, head nuts)
10mm wrench (10% of the fasteners)
12mm wrench (used, once)
13mm wreches of different size, configurations, bends, (all the times, including the exhaust)
15mm wrench (engine / tranny nuts, engine carrier nuts/bolts)
17mm wrech (fuel connections to filters)
19mm wrench (anti-sway bar)
32mm wrench or an oil line wrench (Oil lines)
small med and large torque wrenches (all over the place)
0.1mm feeler guage (adjusting valves)
small / med / large flat screw drivers (stabbing yourself in the hands)
small / med / large philips screw drivers (pokijng holes in the shrouds)
oil seal picker (engine main seal)
circlip pliers (removing the only circlip holding the clutch actuating arm)
hammer and a piece of wood (installing oil seal)
gasket set (so your Porsche does not imitate a Ferrari by leaking)
oil and filters (don't reuse the oil)
jack stands (never crawl under the car w/o them)
2 jacks (one to support the engine, one to support the tranny)
2 small furniture dollies (putting them under the engine to move it around the garage)
one bag of 50 rags (because you are a slop)
jtfreels 11-16-2007 07:22 AM
Wayne's 101 projects book is great for the first time engine drop. Or this tech article
http://www.pelicanparts.com/techarticles/911_engine_drop/911_engine_drop-1.htm
and you really should have German beer!
Jay
Thrlls 11-16-2007 08:18 AM
Mahalo for all the feedback!
I see I'll need to do some PP shopping and use my on line discount. ;)
David E. Clark 11-16-2007 09:18 AM
I'm suprised nobody posted a link to this thread yet: Ultimate SWB Engine Drop Checklist. I know that Woody's car is not a SWB but this is still an excellent checklist!
yelcab1 11-16-2007 10:26 AM
A very incomplete list for an Motronic car.
gigem75 11-16-2007 10:33 AM
cv joint gaskets if you drop the transaxle
Thrlls 11-16-2007 10:35 AM
Mahalo David! SmileWavy
The list will come in handy.
I can't wait to start...my hands are getting rusty and my tools are starting to itch! :D
Thrlls 11-16-2007 10:39 AM
I don't plan on dropping the transaxle, but I may end up doing that once I get started. However, if I do that reasoning tells me to have it rebuilt and then I might as well do the top half...hmmm. Decisions decisions!
Axiom 11-16-2007 10:47 AM
It is much easier to drop engine and trans as a unit, it is for me......what about the beer.
RWebb 11-16-2007 10:49 AM
- You really need to buy yourself a Bentley Manual - the cost will be nil after you do 1 engine R&R.
* Drop the entire powertrain as a unit - do not try to just drop the motor by itself.
- Do a search for engine + drop -- there are numerous threads on this and they are quite comprehensive.
Christien 11-16-2007 10:50 AM
This thread is awesome - thanks! I want to rebuild my transmission over the winter, so this is some great reading.
DaddyGlenn 11-16-2007 11:13 AM
Here is the thread from my first engine drop.
http://forums.pelicanparts.com/porsche-911-technical-forum/310898-here-goes-1st-engine-drop.html
P.S. Drop the engine and transmission as a unit. SmileWavy
DaddyGlenn 11-16-2007 11:18 AM
Originally Posted by RWebb (Post 3592047)
- You really need to buy yourself a Bentley Manual - the cost will be nil after you do 1 engine R&R. ...{snip}
+1 Follow the Bentley step by step and you will be fine.
Thrlls 11-16-2007 11:52 AM
I got the Bentley, 101 Projects, Haynes, and ALL of YOU!
I think I'm in good hands!
I have dropped a 3.0 motor only, but I think I'll take the advice here and do motor & transaxle as 1 unit this time. I want to clean up under the car also, so I think this would be a good time to do it as well with the transaxle out too.
You Guys have been AWESOME!! http://forums.pelicanparts.com/suppo...ys/men_ani.gif
MAHALO!! http://forums.pelicanparts.com/suppo...s/beerchug.gif
rexav8r 11-16-2007 01:38 PM
Corona= ok for a brake job or new air filter, m a y b e ok for an oil change.
Bitburger= Much better choice for an engine drop or valve adjustment (available on tap at the Hale Koa or Boat House don't know where to get the bottles out there !!)
[that ought to stir the pot!]
Don't forget the obligatory photo of you standing up THROUGH the engine compartment, drinking a beer, once you get it out.
-I'm doing an engine drop (and a bunch of other stuff) right now too !!!
CHEERS !
Axiom 11-16-2007 02:30 PM
L A area, way more coronas than bitburguers
No drinking and wrenching
Only one task at the time.
Thrlls 11-16-2007 03:32 PM
I totally agree with you here! It could be just a deadly as drinking and driving, depending on the task at hand.
Okay, time to do as you say....let's see the photo of you in the empty compartment! :D
rexav8r 11-16-2007 05:02 PM
(with respect to: drinking and wrenching)
ok, if you're going to state the obvious safety tips: don't lower the car down on your children when you're done with the project.
(with respect to: photo of me in the engine bay with a beer.)
If I can dig the last one up I'll post it again. I'm going to wait until I've replaced the oil return tubes, heat exchangers and stuff before lowering the motor this time, but I'll get another shot then, ok.
yelcab1 11-16-2007 05:08 PM
Who are you kidding? When it is 85F, the sun is on you for 2 hours, you just wrenched on that last bolt and the engine is out sitting on a dolly ... it is Miller's time and you will drain half a bottle in one gulp.
Axiom 11-16-2007 06:43 PM
I'm just jealous...... I don't get to have a beer during my wrenching hours, and sometimes I think I deserve one, we get to work on some pretty fun projects.
