? exhaust port glazing
Bad valve adjustment or real trouble to come? I removed the ssi today to see this. What do you think?
Old 11-16-2007, 07:38 AM
khamul02's Avatar
Interested Bump.
Tom Hutchinson
80 Targa / 81 Coupe / 71 Targa (in Porsche heaven)
My Garage Build: https://youtu.be/H0n_NwEQVbs
"If one does not fail at times, then one has not challenged himself." Ferdinand Porsche
Old 11-16-2007, 09:04 PM
Does it wash off with brake cleaner? I'm wondering oil/fuel vs something else...
Andy Glass
'86 930 Kokeln IC, K27-7200, SC cams, GHL headers, Fabspeed muffler, Short R&P , misc other mistakes made...
Old 11-16-2007, 10:18 PM
The gloss black is in cylinder 1, 3 and 6. DOES wipe off with a rag., there is some black oil film at times were the other cylinders are dry. The valves in the past have been out of adjustment, were to tight and i guess did not close all the way. no other symptoms except light smoke on start up after sitting along time. not very noticeable. Have anybody else seen this? Mabey the CIS is running rich?
Old 11-16-2007, 10:33 PM
Evolved
Mo_Gearhead's Avatar
If it wipes off with a rag/mild cleaner, it's probably just excessive/unburnt fuel.
If it's a crusty buildup (thick and not easily removed) it's baked on oil deposits and would indicate bad rings/valve guide wear/ valve stem seal leakage/etc.
Check your fuel mixture, IMO that's your culprit.
No worries.
Don't fear the reaper.
Old 11-17-2007, 05:15 AM
running rich
I have had problems with the cis for years, its a 1974 cis on a 80row 3 liter. still runs better than carbs,
Old 11-17-2007, 04:30 PM
Nitrometano's Avatar
my brothers 911 2.7 had that problem after the rebuilt. I dont know what cause that glazzing. I dont know if the engine do it again because I have not taked the headers again.
1972 911T
1991 Mazda RX-7 Turbo II
Are you car loosing power? When was last time you service your fuel injectors? Dirty fuel injectors? Why no try a complete fuel injector cleaning service and return the dignity to you car. Visit www.rennsportfuel.com and we will return your injectors back to life!
Old 11-17-2007, 08:06 PM
