HELP Bilstein shock spacer
I am replacing the inserts on my struts. The large washer/spacer, does it go inside or outside the dust cover.
I rewrote because i thought I found the answer in a previous post but it did not clarify. Thanks, Last edited by wilke3169; 11-16-2007 at 07:42 PM.. Reason: found answer |
sudo apt-get purge 930
It goes between the dust cover and the strut mount.
Mark 1979 930 Euro ***GONE AND DON'T MISS IT AT ALL*** "Worrying about depreciation on your car and keeping mileage down is like not ****ing your girlfriend so her next boyfriend finds her more appealing" --clutch-monkey |
Alii&Maui
If you are going to lower the ride height to Euro or below leave it off.
1982 SC Coupe SCWDP#0087 KCSSL#0082 |
