1967 911 mirror removal
how is the interior rear view mirror removed?
Evolved
Perhaps your earlier car is different (mine is a 69)?
There is a very small, vertical screw that passes up through the 'arm'. That will release the mirror portion. Of course the base uses adhesive to the glass.
Don't fear the reaper. |
Not on a '67. The base of the mirror is attached to the roof with screws. The glued mirrors came later.
Tom Tweed Early S Registry #257 R Gruppe #232 Rennlist Founding Member #990416-1164 Driving Porsches since 1964 |
911
the mirror mounts to the roof not the windshield. no screws visible passes through a rectangle hole in the headliner andd conects to the inner roof panel
"farking Porsche hero"
If there's no screws visible, maybe you've got a '68 mirror, which is mounted on a break-away bracket. There's spring loaded pins up inside the bracket that hold the mirror in. To remove it try (carefully!) to pry it down with a screwdriver. Or, if you're confident the spring loaded pins aren't rusted solid, give it a good yank.
A picture would be helpful.
Rich '66 911 #303872 '07 Cayman '17 Macan '58 Land Rover S2 88" Last edited by Rich Lambert; 11-17-2007 at 08:36 AM.. |
A break-away '68 mirror has a "brushed" finish, while the '67 and earlier were bright chrome. No?
Roger 1968 sand beige 911 Normale coupe #11830091 1984 metallic moss green with champagne interior 911 Carrera coupe 2012 silver with red interior Boxster |
