ground strap ontop of the case?
I started putting the engine back together this weekend. Didn't get to far, b/c I just can't recall where this ground strap goes! I took detail photos of almost everthing I've disconnected/taken apart and it's worked very well up to this point. I've looked thru all my pics and just can't seem to find one for where this goes.
I have several pics of all the connections to the alternator, like this one:
I don't see this ground strap in there in any of the pics. But the way the bend is on this strap seems to suggest that it does go somewhere on the alternator, or perhaps the fan housing.
I do remember removing the diverter from the back of the fan housing. But I don't remember the strap being removed during this step.
I'm a little embarrassed about this. Can anyone give me any insight to the proper location for this ground?
Thanks,
Chris
Old 11-19-2007, 05:44 AM
Ground Cable....
Chris,
This ground cable is attached to one of the lower studs holding the diverter. This cable was detachedd prior to air diverter removal if you recall it. Hope this helps.
Tony
Old 11-19-2007, 06:52 AM
Tony:
That's what I was thinking. But I couldn't really recall clearly. I was just wanting to make sure.
I appreciate the reply.
~Chris
Old 11-19-2007, 07:05 AM
dlagerstrom's Avatar
Mine didn't have a strap like that, but one of the brown wires that goes on the alternator runs to the engine case like what you have shown. Mine was just a brown wire but yours might be older or changed out at some time. I would vensure a guess that it goes to the same terminal as all the brown wires from the harness.
Good luck.
-Dave in Minnesota
96 C4 Cab, 85.5 944
82 SC Targa SCWDP #0023
82 928
67 912 60 T-5 B Cabrio
Old 11-19-2007, 07:12 AM
