gas leak
hi.. i have a question my 79 porsche 911 and its leaking gas from the fuel accumalator line, the one thats going under the car from the engine compartment do anyone know where that fuel line connect to thanks for the help porsche forever.
sylvester
Old 11-17-2007, 03:31 PM
BReyes's Avatar
Have you pulled the hose, you may have all weekend?
I had the fuel lines in my engine compartment replaced with custom braided lines except for one little 4 inch several hundred $ factory line.
The dealership will have a diagram and can order your hose.
Porsche wrench/ hydraulic hose shop could fab lines too.
Goodluck.
Regards,
Bernard
Old 11-17-2007, 04:03 PM
p911dad's Avatar
BReyes, have you bought a Bentley manual for your SC yet? That is a really useful resource to have handy. I believe that line joins a hard plastic line that runs through the tunnel to the front and is a return line to the gas tank. It's not too hard to replace, just make sure you have the parts(our host sells them) before you start. And safely first messing with gasoline!! Good luck.
Old 11-18-2007, 12:24 PM
