-   -   What to do with the chrome when I put my 911T to sleep in the winter (http://forums.pelicanparts.com/porsche-911-technical-forum/378151-what-do-chrome-when-i-put-my-911t-sleep-winter.html)
Svensson911T 11-19-2007 02:30 AM
What do you do with the chrome, when you store your car? My car is in a cold but dry garage. Thanks for your help:)
Milu 11-19-2007 03:01 AM
Clean, polish and rub down with a little vaseline on a rag. Use the wipe on, wipe off method.
356six 11-19-2007 05:42 AM
Check out a motorcycle shop. They have PS1000(?) spray that inhibits corrosion. I've used on my HD a few times, but it is a ***** to clean off in the spring.
Black968 11-19-2007 06:53 AM
WD40 or any spray lubricant works well on any type of metal. It wipes off very easily. Just don't spray it on your rubber trim.
Cheers
Zeke 11-19-2007 06:58 AM
Lots of pure wax is good, too (several coats allowed to dry between coats). Won't work with the other "soft" things mentioned, so it's one or the other. The others will just dissolve the wax.
