FRED/LI
Guest
Posts: n/a
Heater/blower C2
Fan motor failed.. poppoed fuses. We found the bushing at the squirrel cage fan end to be worn and oversize. Machined a new bushing and it seemed fine. However when the fan turned on, it drew enough current to cause a slight drop in engine idle speed. Finally blew another fuse.
Question: What is it specifically that causes the motor to draw more amperage. Is it repairable or an internal fault?
Old 02-26-2001, 10:37 AM
David Griswold
Guest
Posts: n/a
Not sure about your question, but found one for $40...pretty cheap to simply replace it.
Here is the link http://216.64.5.194/scripts/ads/classifieds.cgi?search_and_display_db_button=on&db_id=7206&query=retrieval
Old 02-26-2001, 06:03 PM
robert ellis
Guest
Posts: n/a
There was a factory buletin issued in 91 that increased the fuse rating from 25A to 30A. Which fuse are you currently using?
Bob
90 C4
Old 02-26-2001, 06:14 PM
FRED/LI
Guest
Posts: n/a
Fixed it. Tore it apart and found the fan end bushing worn with shaft flopping within. Removed the bushing and machined a new one out of solid brass. Reinstalled it, lubed the felt washer with oil and graphite grease and away she goes. The fuse was a 30 so someone must have read the bulletin.
Seems foolish to design a unit with bushings instead of bearings for that hostile environment.
Old 02-28-2001, 06:26 AM
