Another Day in Paradise
Is there a tag on the car that lists the options that came with a particular 911? If not how you find that info
85 Carrera 79 BMW R100RT |
The only other way to check all options is to spend $100 bucks and ask PCNA for the factory build info. Half the time though, you are getting junk info. Find Wayne's thread on the Kardex for his 959 and you will see it was not helpful or correct.
Tony G 2000 Boxster S |
Call 1-800-porsche...option 3 I think. Give them your VIN number and they will tell you your options. Monday thru Friday.
madmmac AKA Mitch 1984 Factory Turbo Look 2006 4Runner 1998 TRD Supercharged 4Runner (Sleeper) |
Not much info on hood of trunk-color code, engine, trans. Had read post on PCNA. Will give 800# a try.
