996 Won't Start After wash
Washed my 1999 996 cabriolet last weekend. After being finished with it went to move it and now car doesn't start. Car doesn't even crank now. Any suggestions would be helpful, Thanks.
1. Check for Battery voltage
Are you saying that it doesn't even turn over? Does power come on in the car? Did you wash the engine compartment?
Mike the 911 Camper 83 911 SC 73 914 Conv. 6 Engines should be as the World once was; flat and full of adventure. |
Post on a 996 forum..
try rennlist, renntech, or 6speedonline.
jasper 2002 996 - arctic silver - PSS9, H&R sways,X51 oil pan, console delete, AASCO liteweight flywheel, gbox detent, RS motor mounts, 997 shifter. Great car. past: another 2002 996 and a 1978 SC with-webers-cams-etc. |
just me
distributor is wet?
does it even have one? happened to me once the cover was a little loose
1975 911s, 3.2l and 915 transmission front oil cooler RUF replica bumper ducktail and SC rear flares SW chip ssi's m&k 2 in 1 out sc front calipers PF 97 pads fuchs 16 x 7 and 8 225/ 245 toyo ra-1s 22/29 torsion bars 25mm Charlie Bars Neatrix bushings lowered and corner balanced DAS bolt in roll bar kirkey seat 5 point harnesses. http://www.hairydoggrrrage.com/ |
Car seems to have good voltage. Lights come on in dash like everything is fine, just no crank
Canadian Member
Even if the distributor was wet/problem the car would still turn over.
When you turn the key to the start position it engages the starter. If the starter is not getting power; its likely a battery problem. Check your connections, check your starter connections. If the battery checks out good and connections there are good, you can run a booster cable to the starter connections and run the power direct, touch the "+" to the starters "+" and it should engage the starter to show that the starter is functioning OK? From there we can continue if you haven't pin pointed your challenge........ Good Luck |
