(the shotguns)
berettafan's Avatar
New suspension pan; Seam sealer before or after POR15?
Finishing up my suspension pan installation and i'm not sure if i should put the POR15 on before or after i brush in the seam sealer.
I'm worried about the POR sticking to the seam sealer if i put the seam sealer in first.
Thanks for the help!!!
Erik
Old 11-25-2007, 12:44 PM
1972_911T's Avatar
I would say por first if you read the instructions por15 should ideally be in contact with bare metal to work properly. Then seam seal ontop of this you may need to use there tie coat primer to get the sealer to stick properly to the por or maybe just degloss it with some wet and dry?
1972 911t RS Styled
G50 conversion underway
1972t Resto Project - http://www.ddk-online.com/phpBB2/viewtopic.php?t=16695
Old 11-25-2007, 01:18 PM
I would check with the POR-15 people, dont get this wrong! The seam sealer has a very important function over welds to stop rust in small pockets. I dont know if POR has the ability to get into all the small holes to eliminate air pockets.
PS: I am no expert but I have read quite a few treads about this and recently did the same job, but with other more traditional materials.
John
997 C2S 2005 "Slate grey"(special order 1965color)
911 SC 1978 Silver/black 34.000 miles from new!
911 2.2 S 1971 Albert Blue/Black and 911 2.2 T 1971 Tangerine/Blood Orange/Black
Sold: 911 2.4 S 1973 Viper Green/Kelly Green; 993 C4S 1996 Black/black; 993 C4 1994 Black/Black; 996 C4 2000 Black/Black; 996 Turbo 2003 Silver/Black
Old 11-25-2007, 02:09 PM
If you check their website, I belive POR-15 make a seam sealer of their own, or at least it is a thick formula that comes in a caulking tube and is meant to be used as such. At the least, I would seal over the POR-15 as Steve said, since the POR is supposed to be contacting metal.
L.J.
Recovering Porsche-holic
Gave up trying to stay clean
Stabilized on a Pelican I.V. drip
Old 11-25-2007, 02:58 PM
(the shotguns)
berettafan's Avatar
thanks guys. i will use POR first as your comments make a lot of sense.
Old 11-25-2007, 03:16 PM
