pjv911's Avatar
Send a message via AIM to pjv911
Twin plug stuff. Need help to ID
I found a bag of ignition parts marked twin plug dist parts. Inside I found 2 brass gears in the oem packages showing part # 547.09.248
Also found 2 caged bearing assemblies also in oem bag and with part # 900.052.007.00
Lastly there is a neat looking plate with two sets of points mounted but no part #. See pictures
Who has the knowledge to id this stuff?
Never drive faster than your gaurdian angel can fly.
82 SC w/965S eng and G50 6:1 hp/w ratio
72 911t 2.6 twin plug and 72' 911t 57k orig 1 own miles
65/66 912 1 owner 76k orig
01' Aston Martin DB7 V12 Vantage Coupe 6spd
Old 11-25-2007, 12:41 PM
points plate
that looks like the fuel injection trigger points for the 914-4
Mike Bruns
The two most useless things to a driver are the braking distance behind you and nine-tenths of a second ago.
Old 11-25-2007, 02:13 PM
pjv911's Avatar
Mike Bruns
That would make sence because the terminal plug looks kinda new to be a twin plug part. Do you know for sure or does it just ressemble a 914/4 setup?
What about the bearings?
Old 11-25-2007, 02:32 PM
points
There should be a bosch part # on the piece something like (0 xxx xxx xxx x )
post the # and we can figure it out. I can't tell by the pic what they are.
Mike
Old 11-25-2007, 03:23 PM
