1984-911 M491
Trog's Avatar
Radio Install - Becker/Porsche CDR220
I just took delivery of a Becker - Porsche CDR220 radio and noticed that it didn't include a slider (metal box that clips into dash to support radio). Anyone know if I need one to install this radio, or does it just plunk into the hole in the dash?
I don't have the original Bluapunkt for my 84-911, so I have no idea if a slider (also known as a DIN cage) is required for these cars.
Anyone?
Old 11-21-2007, 06:25 PM
I've not seen a DIN radio yet that didn't need one.
JR
Old 11-21-2007, 06:54 PM
1984-911 M491
Trog's Avatar
That's pretty much what I figured. Any idea were I can get one?
Old 11-21-2007, 10:03 PM
newb.
eimkeith's Avatar
no cage on the DR-220.
keith
'75 RS/RSR-look | '73 CB750 | '70 TD250B
r gruppe #436
Old 11-22-2007, 01:17 AM
911 carrera 3.2 (1985)
kees's Avatar
Becker
I have the same radio and my car is a 1985 911 carrera.
There's no need for a DIN cage. You can adjust the Becker radio and then it just clicks in.
Old 11-22-2007, 04:37 AM
Keith,
You sure about that? How would you secure it to the hole in the dash of an early car without one? What would the locking tabs on the sides engage?
JR
Old 11-22-2007, 04:38 AM
buttjoint's Avatar
I don't think I used a cage. When you install it and can't see the screen, You can send the face plate to becker and they will reverse the colors so you can see it. Much nicer. Also If you can get the amp that goes with it, Works sweet
Old 11-22-2007, 05:26 AM
1984-911 M491
Trog's Avatar
Really? And it doesn't flop around when you hit bumps? Do the side tabs lock onto the dash opening? I didn't notice any adjustments on the radio?
Any chance of taking a photo from the underside?
Old 11-22-2007, 08:00 AM
If you need one I have a spare and I live out in Scurrey
Old 11-22-2007, 11:45 AM
87coupe's Avatar
For the adventurous you can do this yourself by simply rotating the polarizing layer that covers the LCD. I've done it on multiple devices including one of my g-shock watches.
ßrandon
Old 11-22-2007, 11:51 AM
1984-911 M491
Trog's Avatar
Yup, I'm interested. I'm in Richmond
I've sent you a message.
Old 11-22-2007, 02:08 PM
Absolutely sure the unit should slide in just like that.
Kept in place by the 2 springloaded flaps on the sides of the radio.
I made a bracket to support the bottom of the radio to make it more stable.
I have a Solisto added to my unit: this is a device that you connect to the CD changer port of the unit and allows you to play MP3 files from an USB stick.
You control the Solisto identical to a CD changer from the frontpanel of the radio.
Superb thing. For details drop an email at info@solisto.nl, guys are very helpful.
Better a good one for a lot of bucks, than a bad one for little
Old 11-25-2007, 04:13 PM
scottb's Avatar
Since, obviously, there's a difference of opinion as to whether you should have a cage, my suggestion would be to call the service department at Becker North America. They're usually very helpful.
http://www.beckerautosound.com/
Scott
1984 Targa
Old 11-25-2007, 05:19 PM
1984-911 M491
Trog's Avatar
You are correct, Radio went in with no need of a DIN sleeve. Matter of fact, a DIN sleeve will not fit this Becker. The OD of the Becker has the same dimensions as a DIN sleeve OD. I didn't seed to fab a bottom bracket. It's pretty snug the way she is.
Thanks for the heads-up on the Solisto.
Ciao,
T...
Old 11-25-2007, 05:20 PM
