The Padding - Best Way to Remove
Hi Kids,
What is the best way to remove the rear padding on an old tub? In this case, "best" means fastest and least amount of airborne fluff.http://forums.pelicanparts.com/uploa...1196037470.jpg |
How about heat gun, I recent removed the vynal and pad off of my glove box. My .02
I believe you are indicating the sound deadening padding. It's all one piece and heavy as hell. I just lifted mine up off of the metal shelf & seats. It wasn't stuck on very well. If you want to save it, do it carefully or it will start ripping. I'd try to start with a loose edge & get under it with a putty knife or some else similary. Good luck.
| All times are GMT -8. The time now is 10:42 PM. |
