Removing AC from '77 911
I'm thinking about removing the AC from my 77 911. Does anyone have the instructions for doing this? Any reason I shouldn't do it?
Old 11-27-2007, 06:01 PM
Jastx's Avatar
How about "you won't be able to cool your interior"? I couldn't stand no AC where I live. I upgraded my system (on my '89) and it cooled as well as any car out there. You don't indicate where you are but if you get temps above 75, I would upgrade, not remove.
John
2005 997 Carrera S -- Artic Silver/Sea Blue
Former friends: 1989 930 factory Slantnose /
1998 C4S Coupe / 1973.5 911T / 1976 914 2.0
Old 11-27-2007, 06:42 PM
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 11-27-2007, 06:48 PM
poorsha's Avatar
I just removed mine but the instructions are in my head.
Email me. I may be able to help.
poorsha@shaw.ca
Old 11-27-2007, 07:38 PM
Noel's Avatar
It is actually pretty easy. ONce the system is empty, just start unbolting everything slowly, including all of the hose brakets, etc. It took me a solid day to do this and I have never missed it. Total weight, per my scale was about 75-80 pounds including all hoses, brakets, etc. The SC compressor and mounting brackets are pretty heavy
Gone but not forgotten -
1980 Porsche 911SC w/ -22mm/28mm Torsion Bars | Custom Valved Bilsteins | 22mm/21mm Carrera Sway Bars | Elephant Poly/Bronze Bushings | Carrera Brakes | AJ-USA Brake Cooling | Carrera Oil Cooler w/ Fan | Elephant Strut Brace | Oh, and no ABS or PSM or A/C
Old 11-28-2007, 08:25 AM
