-   -   CIS rebuild threads? (http://forums.pelicanparts.com/porsche-911-technical-forum/379458-cis-rebuild-threads.html)
SCWDP911 11-26-2007 10:52 PM
I just spent the last hour or so trying to find info I was sure is here somewhere but to no avail on my end. Here is what I want to do: I want to remove my CIS and do a refurb/rebuild on it. Clean it all up, replace all of the vac lines, etc.,etc. I need to know what I should include on the etc., etc list. I need to know what to NOT touch and leave alone. I need to know what "while I am in there's" to consider as part of this. I am sure this has had to have been covered at some point... sorry if it has countless times already... I just can't find it for whatever reason.
1982911SCTarga 11-27-2007 03:55 AM
Are there hot or cold startup, or driveability, issues that are prompting you to go down this road? Have you checked your pressures? If everything is in spec and performing as it should, why would you want to do this?
Brian
Porsche_monkey 11-27-2007 04:00 AM
Maybe some others will disagree, but I would be inclined not to remove it. I just don't see the point. I think you should post your problems and get some help at finding the problem.
Walter_Middie 11-27-2007 05:11 AM
V8,
Be sure to replace the injector sleeves (911-110-886-03-M260), and have the injectors professionally cleaned by an outfit like Witch Hunter. Even though the fuel distributor (FD) can get gunked up, I wouldn't recommend taking the FD apart. I have seen threads here where some have successfully rebuilt these, but getting them back together without leaking is difficult. I have had mine rebuilt professionally, but I'm not sure where these rebuild places are now.
A few people on here have tested their air box by sealing them up and applying air pressure. I'd love to do this to mine, and I think it's a great idea.
boyt911sc 11-27-2007 06:08 AM
CIS Component Rebuilding......
V8,
The final decision is yours to decide whether to do it or not. But if I were you, I would heed to above suggestion. Do you have any compelling reason why do you need to disassemble or refurbish the CIS components? What problems if any are you experiencing with your CIS? Is your motor out already from the car? Finally, do not disturb or tinker the FD and air flow meter units unless you know what you're doing. Just my two-cents.
Tony
914efi 11-27-2007 06:46 AM
Get 6 jelly jars and run the injectors into them. Place a socket or some other proper item under the 'flap' to create a fairly small opening it it and turn on the fuel pump with all of the injectors having been recently run so that they are 'primed'. If all of the injectors flow the same amt, you can safely assume the everything is reasonably good. If they do not flow the same, one might be dirty, etc. You can switch it and see if the flow amount follows the injector or the system. Work your way back to the FD. Check spray pattern from injectors also. You can also run the pump and open the flap all the way, this will push out junk that may be in the system. Check injectors for dripping after shutdown also. These injectors are really simple, not much to go wrong and nothing to fix when they do go wrong.
FD can be bought rebuilt or can be rebuilt for a bit less than $500.00. If flow is good from it, you can probably take apart and clean if you are very careful, but if you cause damge you will be screwed as you might not have a rebuildable core.
As asked above, what is going on now?
84toy 11-27-2007 08:50 AM
I too save every CIS thread and would like more....I have the 2.7 Daughter Project" engine sitting here and ready for rebuild. It's been sitting for about 10 years so the fuel\CIS system would warrant a complete go-through and cleaning
Gunter 11-27-2007 09:25 AM
The type/year would have helped so that one doesn't have to look up your profile.
An '83 SC has a lot of Lambda stuff and extra electrical components.
If you have them, the fan blower and A/C is very much in the way and a lot of the important parts are in the back.
Pretty hard to inspect/replace the vacuum lines or clean/check components in situ.
I have done several and would suggest that it's easiest with the engine out. :)
The gaskets and boots on the runners need replacing and are almost ipossible to reach, injectors cleaned and O-rings replaced etc.
Ricks911s 11-27-2007 10:09 AM
84Toy - I see you are from Sacramento. Currently trying to get a 76 back on the road (despite their inherent problems). I've learned a great deal on CIS . . . but learn more with every thread. Let me know if you ever need a hand.
j_mancini 11-27-2007 11:39 AM
v8_ranch ~ Check this thread out, might be of help to you:
http://forums.pelicanparts.com/porsche-911-technical-forum/367288-cis-problem-tested-have-results-opinions.html
I did a full refurb of my CIS this fall.
Walter_Middie 11-27-2007 12:10 PM
John - I missed that thread. Great job! I like it!
Several people have said not to remove the CIS system from the car. But obviously a few have - and done so successfully. My car is a hobby - I take it apart just for fun. This could be a great learning experience for V8. I say go for it. It seems like there is a lot of old rubber parts that may need to be replaced on a car this old.
SCWDP911 11-27-2007 12:32 PM
All,
Thanks for the reponses. The reasons for my thoughts about doing this are more than one:
1. I do have what I suspect to be a slight vacuum leak somewhere, as I have a slight hunting idle (am I right to suspect vac leaks here?)
2. I have recently started having a problem with the idle turning way low (like 250-400 rpm). It will stay running barely and then it will clear up after I drive it a bit. But, as I stated on an earlier thread, it seemed to really stand out after a hot restart. And the weird thing kindof, was that Jay Freels(also and SC with CIS) started having a very similar problem during the same trip we all made to Arkansas for the Porsche Palooza.
3. As someone else stated, it would be nice to replace the 25 year old rubber components, and as a side benefit to this, the vacuum lines would be all nice a purty again!
4. The car smells like it is running rich, which sounds to me after reading here awhile is better than running lean. I would just like to make sure it is all optimal.
5. And finally, I would just like to clean up the whole area - very thoroughly.
That all said, I work in the gas turbine industry, and believe me, I know there is a fine line between "don't fix it if it ain't broke" and "and ounce of prevention...". I just wasn't sure about the specifics of what I had in mind, hence the question. I would like to make it as minimal invasion as possible but still clean and replace 25 year old rubber.
Perhaps I should get it operating at optimum first, and then do the clean and replace work? my gage set has not yet arrived, so I cannot really start any detailed checks yet. I DO have a coupe of books that look to have good and pertinent info:
1. "Solving Bosch CIS Problems" by James Weber
2. "How to Tune and Modify Bosch Fuel Injection" by Ben Watson
From reading the earlier posts, it sounds as though to do part of this work, it might be easier or necessary to drop the engine? I guess that would be an excuse to get the first one out of the way. I have a friend close by that is building an RSR and he has dropped his numerous times, so I have a good resource for help there.
John - I missed your thread as well. Don't know why I could not get when searching the last couple fo days. But thank you for the link. I will look at it next.
Gunter - (I ask this seriously) are there more than one type of CIS (besides euro and US) that would be found on an 83 car? I ask just because I have my car labelled in my sig. Maybe I need to add more info to it. Thanks for poining it out.
Thanks again everyone. Looks like I have some more research and thought to put into this. Hopefully my gage set will get here soon.
SCWDP911 11-27-2007 12:36 PM
John, OK time to backpedal... I'm an idiot. I did see and read through your thread. I am the one that contacted you about the airbox test rig. Duh on me.....
1982911SCTarga 11-27-2007 12:39 PM
The CIS gauge set is critical to correct diagnostics. Start there so you know your system and control pressures are either good or bad, and check for vacuum leaks. After that, your troubleshooting will determine how far down the rabbit hole you'll have to go.
Don't fall into the trap of shotgunning parts and guessing, and it sounds like you won't because you're doing your research.
Just my view, but it's way easier to be completely thorough with CIS R&R'ing with the engine out and on a stand. But I'm waaaay down the rabbit hole with my project '83 cabriolet right now. Actually, it's a sort of while-you're-in-there rabbit hole. ;)
Brian
dtw 11-27-2007 12:53 PM
Here's all the stuff I did when resurrecting my '76 911S CIS:
-Flow test injectors
-Replace injector o-rings and plastic isolation mounts, re-stake mounts
-Replace six rubber intake runner to airbox boots
-Check epoxy around popoff valve
-Check and replace as needed rubber isolation mounts on brackets
-Check throttle plate seating in fuel distributor body, clean all surfaces carefully
-Check freedom of movement of fuel head actuator rod
-Check and replace as needed vacuum lines (90% required replacement)
-Pull aluminum warmup valve piping, grind corrosion at hose fittings, polish smooth
-Check and replace as needed all fuel lines/hoses (replaced pretty much everything but injector lines)
-Replace intake runner gaskets
-Remove & reline fuel tank
-Replace fuel filter
-Replace fuel pump
I'd probably have gone through a lot of checking of the cold start devices, but frankly there's just not a lot of need for it here in NC.
Fidalgo911S 11-27-2007 01:57 PM
That's a good list dtw came up with. I did most all of this except the replace the fuel pump. It was working fine and I saw no need to replace it. Replacing all the fuel and air hoses is a must, even the ones you think look fine. It's cheap and with all the trouble you took to remove the CIS, it's good insurance. All in all it wasn't that difficult (especially when compared to MFI or my 914's L-Jet system). I mostly cleaned everything I could and reassembled. My only big ticket item was new injectors. Witch Hunter does good work and I've used them before, but I found a set of six new ones for cheap.
Don't forget an ignition tune up at the same time - spark plug wires make a big difference ;)
dtw 11-27-2007 02:03 PM
Yep - replacing fuel pump just for grins is likely not necessary - mine was plugged with debris/varnish. Found a cheap and excellent replacement for the spendy Bosch pump with a domestic Walbro.
The injectors don't last forever. I had to replace half of mine.
Heh, the 'while-you-are-in-there' bug can be bad. I also did plugs, wires, cap, rotor, points, coil, etc.
Ricks911s 11-27-2007 02:40 PM
. . . as someone else always says on their threads . . this is my $0.02. .
I'd like to echo what dtw and others are saying. I'm by no means an experienced mechanic. I suppose it boils down to your budget, your ability, and your experience with these cars. For me my budget is small, my ability is average to good, and my experience was null when I started (now quite a bit better). But I always love to learn and love the challenge a Porsche presents. An experienced veteran (not me . . . but some here are) will have insights in ways others of us will not. And lastly there is always the most important part -- WHAT KIND OF CONDITION IS YOUR CAR IN?? No one knows that but you - or a good mechanic if you have one. But that's where the fun comes in because it's the part you control, you fix . . . you succeed. When you fail you learn - okay, that part I should have left to someone else.
Based on my vantage point . . . CIS is something you take your time at. I know that a lot of people -- when they talk about CIS -- make you feel cautious. Probably all of us with CIS are a little paranoid about it. But if you take your time, take heed of the RATIONAL advice, and keep your own records . . . you can figure out almost anything. I'm dealing with a cold start issue, hunting idle, and a pretty big oil leak (not CIS). But I've taken my time and have made a lot of progress.
If you are worried about aesthetics in the engine bay. . . that's something different. I'd rather spend the time elsewhere. But I know the feeling of being inspired by a drop dead georgous engine. I just can't get that religious about a car. Let us know what route you take.
boyt911sc 11-27-2007 07:18 PM
CIS is an old and antiquated fuel injection technology compared to EFI. Replacement parts are getting really expensive and some difficult to find. Except for CDI that has numerous electronic components, and FD (fuel distributor) a very precise metering device, the rest of CIS components are easy to test in or out of the car. For example, WUR, CSV, AAR, AAV, fuel accumulator (FA), fuel pump (FP), thermotime switch (TTS), fuel injectors (FI), etc. all these could be tested using simple tools like multi-tester, test light, fuel pressure gauge kit, and so on. So being able to determine which of these CIS components is defective or malfunctioning gives you a better sense of direction in trouble shooting your problem. Having said all of these, another important part of CIS that is commonly over-looked is vacuum or unmetered air intake.
In summary, a dependable and reliable CIS car is attainable and will last many years of enjoyable driving if properly maintained. With the collective knowledge and experience of the members of this forum, there is no CIS problem that can not be diagnose or corrected.
Tony
