EDIS 6 Trigger Wheel
Does anyone know where I can get an EDIS 6 trigger wheel 36-1 already mounted on a 911 crank pulley? I know Clewwet do a 60-2 but not the 36-1
Steve |
GoingSuperFast.com sells an aluminum pulley with a 36-1 trigger wheel that bolts to the the back of it. I'm using one.
I got one from the scrapyard for $2, drilled 3 holes through the wheel and pulley and its served perfectly ever since.
The aforementioned vendors also have good stuff. |
BTW, it may adversely effect the crank balance as the stock pulley is much heavier and appears to be balanced with the crank. |
| All times are GMT -8. The time now is 07:38 AM. |
