Quality
My Uncle has a beautiful 95 Carrera4 that he has been keeping in the garage for quite some time. It has about 4k miles on it.
What does he need to do to keep it safe and happy? I would figure Brake/Clutch Fluid Anything to do to the rubber hoses (Baby Powder? I think he has been doing that) Getting it off the tires would be nice but probably not happening Oil Change before serious drive No coolant, last year for air cooled ![]() Fuel Stabilizer (Don't think he uses it but should) ? I think the hood struts are shot so I think those would make a decent Xmas gift. Anything else? =) Try not to flame too much, I know the car is meant to be driven... =)
85.5 944 NA 5spd - Sold but not forgotten 89 951 Turbo S - Revival in progress...
naturally aspirated
I looked at a very low mileage 911 once and the brakes were seized.
Just curious, what is he keeping the car for? |
Quality
Me, apparently. It's my Uncle's, he drives it on 'perfect' days only. =)
911_pilot
Carrera 4 sitting for a long time
Regrading the Carrera 4 with 4K on the clock. Someone could be very lucky here...or very disappointed. Adrian Streather is perhaps the world authority on the C4. Having owned a nice '90 model I was amazed that the complexity of the systems working together did so in a wonderful manner. Until something went wrong. I now enjoy the simpler '86 Carrera Sport.
My advise is getting your hands on a copy of Adrian Streather's book,Porsche 964 Enthuestists Companion. He also has a book on the 993 C4 that is considered the Bible. Do NOT attempt any brake bleeding, brake work, or any repairs until you have read up a bit on this particular model. Example: Your mechanic will need a Bosch "Hammer" to bleed the brakes, adjust the hyd. clutch, or to adjust the PDAS system....which all work together off the same hydraulic pump. The Rennlist has a lot more on the 964/993 models. 911_pilot |
I would suggest a strict regimen of track days.
Mike 1976 Euro 911 3.2 w/10.3 compression & SSIs 22/29 torsions, 22/22 adjustable sways, Carrera brakes |
Quality
What's the Bosch 'Hammer'?
I am pretty sure he has been...
Things I want him to do
Basically I am looking for gift ideas for Christmas centered around the 911. Budget ~$100. Books, fuel stabilizer, seem like a good idea. Thinking of getting a Haynes manual, or do they stink for this particular vehicle?
Your uncle must be very strict on determining what a perfect day is in NJ! (I lived in Bergen County for nearly 4 years and they have a lot of great days). Incredible to find a low mileage example like this. Its value is through the roof for such a car (way over regular street prices).. pics pics pics. thanks, l
Luis "once was - Wickd89" Carrera 3.2 - "Faster, Stronger, Better" -- 2008 Toyota Camry SE V6 (mine) -- 2005 Toyota Sienna (hers) -- 1989 911 Carrera Cabriolet -SOLD |
It'll be legen-waitforit
Baby powder on hoses, that's a new one on me....
Anyway if he has not been using fuel stabilizer, I would think the entire fuel system is shot and probably has some rust in it. (I hope not though) Drive it drive it drive it...enough said.
Bob James 06 Cayman S - Money Penny 18 Macan GTS Gone: 79 911SC, 83 944, 05 Cayenne Turbo, 10 Panamera Turbo |
Quality
If you keep the tank full you do not allow water condensation on the walls, protects the system...
I have some pics floating around. Even has the bra on the front to protect it... =) Still want more tips/Xmas suggestions
Yes but fuel starts breaking down in about 3 months.
Get him a PCA membership and select NNJR as your local region. Get him to drive the car to a Drivers Ed and see what the car was built for.
Tony G 2000 Boxster S |
'nuff said.
1980 911SC #99 track car, 993 3.6, 50 PMO's 2019 Ford F150 da dragger 2015 MB SL400 wifey DD 2008 E93 M3 DD 2007 E60 530 wifey winter beater Last edited by SCOTITUDE; 11-29-2007 at 08:53 AM.. |
http://www.durametric.com/historyofporschediagnostics.aspx When he starts it (there are pros and cons to this) but he should at least run it long enough to be at operating temp for a half hour or so. No Haynes (or Bentley) for that car. See other post for good books. Rotate tires? Aren't front and rear different sizes? Unless they're pretty new tires, I would not rotate side to side now; could break belts. Off the ground is not a bad idea. |
Quality
He had a 911 turbo before (I suppose late 80s), C4 Corvette, 944, etc...
I agree, car should be driven... Will look at those books and the Bosche hammer link. =)
Sports Purpose 911 Driver
James Shira R Gruppe # 271 1972 911 Coupe 3.8 RS ‘nbr two’ 1972 911 Coupe 3.2 TwinPlug MFI 'Tangerina-Jolie' 1955 356 Pre A Coupe ‘old red’ 1956 356A Emory speedster build in progress |
should be driven to full op. temp at least once a month
carrera coupe 85 |
