Scissors lift clearance
I just bought house with a 24' x 50' with 8' ceiling. I am in the market for a scissors lift. I keep seeing guys having to build ramps to get their 911's to drive over these lifts. Is there one made with enough clearance to drive a 911 over?
This lift has a 4 3/4" height when dropped.. how much room do you need? Seems like 4 3/4 would be enough???
http://www.pacetools.com/Products/VMR-6S?k_id=312373
JP
'76 911s Ice Green Metallic bone stock
Old 01-05-2008, 04:56 AM
Hack Mechanic
rsiegel's Avatar
I have the BendPak MD6XP. The construction of all of the mid-rises that I've seen is very similar. I'd recommend that you just assume that you need to make ramps of some sort. I don't think that looking for one that's low enough would be fruitful for you. Even my BMW 318ti -- not a low car -- needed a few inches more clearance so that the highest part of the lift wouldn't rip open the cat.
BMW CCA Roundel Magazine, "The Hack Mechanic"
Author, five books available on Amazon
Personally inscribed books available at www.robsiegel.com
Nine vintage BMWs and a dead Lotus Europa that seemed like a good idea at the time
Old 01-05-2008, 05:52 AM
rallyracer's Avatar
Wow! Graced by the likes of Rob. Love your column, coming from a 10+ yr BMW CCA member.
On the lift, I can't even get my E320 over mine. Two stepped 2x8 boards seems to be the easiest solution. Allows for easy parking too.
1983 911SC-Sold!
Old 01-05-2008, 11:05 AM
MBAtarga's Avatar
Oh, that clearance! I thought some vendor had a special on the lifts...
Mark
'83 SC Targa - since 5/5/2001
Old 01-05-2008, 02:32 PM
or...
you could chop a shallow pit into the floor and have the lift installed in it. I have a buddy who has a lift in his garage that way. Parks over it most of the time.
just an idea...
Old 01-05-2008, 03:06 PM
Car underside clearance......
JP,
A typical 911 with Euro height will not clear a folded down scissor lift. The lifting arms will scrape the underside of the car. Solutions: Wooden ramps or build a 4" deep pit to accomodate the lift.
Tony
Old 01-05-2008, 03:25 PM
