help, correct rear Grille for 3.2 (metal or plastic?)
hi, please, what is the correct rear deck grille for 3.2? plastic or metal?
---the difference between insanity and genius is success-- |
Rescuer of old cars
Mine is plastic. Pretty certain it's original.
2018 718 Cayman 2.0 Priors - '72 911T coupe, '84 911 Carrera coupe, '84 944, '73 914 2.0 |
hi, thanks, this is correct? (is fit on deck carrera 3.0)
FS plastic rear deck grille whit hole 170Euro worlwide shipped
AutoBahned
plastic - amazingly, it saves no wt. over the metal ones
Here's a question I've been pondering and I guess this is a suitable thread for it;
A My plastic grille is lookiing a little faded would it be advisable to paint it as part of the cosmetic restoration of my car, or would it look bad painted because the part is plastic?
1984 ROW 911 Carrera Pacific Blue Metallic Practically no options other than sunroof and custom paint. 2009 BMW E90 M3 Interlagos Blue |
Formerly known as Syzygy
Use a plastic paint like that made by SEM. Whatever a local body shop supply has for that purpose will be fine. Maybe wipe your grill down with a rag that's wet with alcohol or an alcohol pad to get rid of any oils and such. Lightly scuff with a Scotch pad and wipe or blow off any dust and crap. Spray a coat of a plastic adhesion promoter made for the paint you're using (follow instructions on can). Then spray your black over that with several light coats.
Don't forget to do your T-bolts, too. Poke them through a piece of cardboard or something so they stand up nice and you don't have to handle them. Easy peasy. I did mine and it looks new.
Kevin 1987 ROW coupe, Marine blue, with a couple extra goodies. The cars we love the best are the ones with human traits, warts and all. |
Thanks Kev more good advice. I think painting the grille along with the air intake grille just in front of the windshield are two near term projects I can sink my teeth into during the winter hibernation. Will work on figuring out some other ones to keep me busy.
Dial 911
A great product
Hi...I have used SEMs products for many years and their exterior 'Trim' paint for plastic or metal trim parts such as wiper arms is excellent. It leaves a factory finish in both color and sheen.
'. Before scuffing/sanding wash items with hot/warm water well. When dry clean with a Silicon wax/grease cleaner. As already mention use a 'plastic prep'. All can be purchased a your local automotive paint or parts store. You can purchase the paint in quarts/ gallons to spray with a gun or by normal spray bomb type cans. As a matter of interest, SEM is huge in aircraft interiors repairs for decades such as Boeing's. Cheers
Cheers! “Simplicity is the ultimate sophistication.” Leonardo Da Vinci Last edited by A horse with no name; 12-10-2012 at 08:24 PM.. Reason: edit |
