expatriot98
Guest
Posts: n/a
Post Question on steering shaft noise
The steering column on my '70 E has the normal squeak that many do. It doesn't seem to have excessive up and down play though. Today, I took the wheel off to investigate and see if the plastic bushing was bad. I discovered that mine is different from the pictures in the Pelican tech article. I assume the pictures are from a later model, Any ideas where to go on this? Below is a picture I took.
Thanks,
Mark
Mark B. Wilson
http://www.marksobsessions.20m.com/
[This message has been edited by expatriot98 (edited 03-05-2001).]
Old 03-04-2001, 06:07 PM
expatriot98
Guest
Posts: n/a
Question
Heeeeellllpppp please. My car is apart and it's nice weather.
Mark
Mark B. Wilson
Old 03-05-2001, 01:14 PM
Superman
Guest
Posts: n/a
Post
I don't have any experience with early Porsches but I can offer these observations: The parts in the picture appear to be in excellent shape. Your car has obviously been cared for very well. If the sun is shining, I say put the steering wheel back on and drive.
The rule is, no more than one hour of maintenance or repair work for for every 2 hours of driving. Absolute max.
'83 SC
Old 03-05-2001, 01:51 PM
expatriot98
Guest
Posts: n/a
Post
Thanks Jim, went back togather with it, but still have a squeak when turning.
Mark
Mark B. Wilson
Old 03-05-2001, 02:23 PM
BRAINIAC
Guest
Posts: n/a
Post
I'm going to make your day if I'm right, and I think I am. What normally squeaks is the horn contact against the the contact ring. A little grease on that ring will likely cure the noise.
Tyson Schmidt
72 911 Cabriolet
Old 03-05-2001, 07:27 PM
BRAINIAC
Guest
Posts: n/a
Post
Just took another look at your picture and the ring does definitely look dry as a bone. (it's the brass ring about 3" in diameter)
Tyson Schmidt
72 911 Cabriolet
Old 03-05-2001, 07:29 PM
expatriot98
Guest
Posts: n/a
Post
Thanks Tyson, I'll give it a lube this aft.
Hey, I saw the Fenix Undergroud in a news clip. Has it risen again yet?
Mark
Mark B. Wilson
Old 03-06-2001, 03:55 AM
Allan Broadribb
Guest
Posts: n/a
Post
I had a squeak and some play in the steering wheel. I fixed the movement in the steering wheel using a shim made from a beer can (Fosters I think). I lubricated the whole thing before putting it back together.
No squeak and no play - cost about 75 cents for the beer though!
Old 03-06-2001, 01:34 PM
expatriot98
Guest
Posts: n/a
Post
Fosters huh? Now that's Beer......
Mark B. Wilson
Old 03-06-2001, 02:17 PM
Allan Broadribb
Guest
Posts: n/a
Post
Yeah - it's not bad. I'm hoping one day I'll need a shim about the thickness of a keg!
Allan Broadribb
'70-911E, 2.2l with Webers
Old 03-07-2001, 05:04 AM
