led lights
Hello guys, I just installed some LEDs BA9 in red for my white gauges and noticed it doesn't light well. I did alot of research on this site but can't find any on brightness info. Is there a big difference between a regular led bulb and a 4 bulb? Or does it light up the same? My friend advised I can add a relay which will brighten the LED, but I thought you can't with LED's. Correct me if that's wrong. Thanks.
Old 12-04-2007, 09:24 AM
3.2 CAB's Avatar
I bought some of the LED lights when they were first being offered. I installed them and found that my factory bulbs actually worked a lot better than the LED lights. I bought a set of the Super Bright White lights and a set of the blue ones. Neither type was very satisfactory, so I re-installed my factory type bulbs, and they did a much better job of lighting the gauges. I now have 2 sets of the LED bulbs in my tool chest, the Super Bright White and the Blue types.
84' Steelslantnose Cab.
1953 Dodge B-4-B-108" 90,127 miles
1953 Dodge B-4-C-116" 58,146 miles
1954 Dodge C-1-B8-108" 241V8 POLY
1973 Roadrunner 440-SIX-PACK*
1986 F-250 Super Cab-460 V8 tow
Newest additions-
Matching numbers 1973 340 Road Runner!!
1948 Dodge B-1-F-152" 1-1/2 ton Dump body, 39,690 miles
others...
Old 12-04-2007, 10:24 AM
Michael Delaney wanna-be
Netspeed's Avatar
The big problem with LEDs is that although they may be as bright as a comparable incandescent bulb, they are very directional and don't spread the light as well as regular bulbs. Also, (and I could be wrong), I don't think adding a relay will help because it's not a bulb that needs more voltage...it's a diode.
88 Carrera Cab
C.R.A.P. Gruppe Member #7
Old 12-04-2007, 10:28 AM
old man neri's Avatar
Ya, from what I understand it's the directional thing. However, you can purchase LEDs that are 'wide angle'. That might help.
Old 12-04-2007, 10:51 AM
scottb's Avatar
There are a bunch of threads here that deal with using LEDs in gauges. Search again, and try different search criteria. You'll find them...
1984 Targa
Old 12-04-2007, 02:25 PM
