-   -   964 to RSR conversion question (http://forums.pelicanparts.com/porsche-911-technical-forum/380975-964-rsr-conversion-question.html)
chancecasey 12-05-2007 05:43 PM
Anybody do this, and notice something funny with the front bumper? I'm trying to fit the RSR widebody bumper on the front of my 964, and the bottom of the bumper is a good 2+ inches from the bottom of the front pan of the car. Further, the forward indentation of the front "wall" of the car, to store the jack, interferes with the bottom edge of the bumper as well, so I think I have to cut the bumper.
Wondering if anybody noticed this and what they did, or maybe I just have a really OFF front bumper that is 2+ inches too short from top to bottom.
mjshira 12-05-2007 05:52 PM
chance
This is probably would get more replies over on Rennlist. Geoffrey did this, search there and you should find it. BTW the heater is working great, thanks, it was around 35 today so I was glad to have defrost and heat.
boba 12-05-2007 07:01 PM
Check this thread, may be more than you are looking to do.
http://66.236.61.177/showthread.php?t=318580&highlight=zuffenhaus
chancecasey 12-05-2007 07:37 PM
Yeah I remember that thread - didn't think to look at the pictures but they obviously grafted an entirely new front metal end to the tub and that's a different bumper than what I've got. That is a little beyond the tools and time I've got on hand. So maybe this is a common thing to deal with. If so, that's cool I'll work something out. Just wanted to make sure the bumper I have wasn't way off by being too "short" top-to-bottom-wise.
James - glad the heater is doing the job!
eimkeith 12-06-2007 06:42 AM
Your bumper is normal. The 964 trunk is deeper than the rest, and will protrude below the bumper like you are experiencing.
jester911 12-06-2007 06:45 AM
Porsche Doc did this conversion. I believe his car was in Excellence a while back but he posts here as well. Here is the car he built for sale.
http://forums.pelicanparts.com/porsche-cars-sale/357623-fs-c4rsr.html?highlight=rsr
chancecasey 12-06-2007 12:00 PM
Although he has a different bumper (mine is the 74 IROC RSR or "widebody", not sure), I noticed he has a splitter that *appears* to extend downward of the bumper by a couple of inches. This would be perfect but I don't see it in the catalogs for the widebody version, only the narrow version. Doh.
TRE Cup 12-06-2007 12:32 PM
chance
there is no extension for the bottom of the 74 iroc bumper (like a 73 rsr can )
Option 1 is to customize the iroc front bumper . you can extend the face bar section about 1/2-3/4 of an inch and do the same for the lower section. This will give you back 1-1.5 inches. Mind you this is a lot of work and will distort the rsr look a little
option 2 is to section and cut down the bottom of front trunk section on the tub. As it does not serve to mount the front suspension , like earlier chassis, you can angle the cut so it "ramps" the bottom of the car. This can be done a lot easier than modding the bumper and will lend you the correct look you are after
TRE Cup 12-06-2007 12:33 PM
while you are at it, you can also install one of our RSR oil panels to center mount a cooler !
chancecasey 12-06-2007 12:44 PM
That's a good idea - I am playing with the idea of losing my stock 964 oil cooler and going with the one designed to fit in the bumper - though that is more time and $$$ and I'd be cutting up the front of the tub to do it. But if I did, modding the trunk to "sweep up" to the bumper would be a realitively easy "while I'm in there" thing to do.
My only concern is functionality - it is a race car and having the bottom of the bumper (or splitter) 2 inches higher than it *should* be, and stuffing that extra air under the car, might not be so great. It would be interesting to know if the increased 964 *height* dimension in front (compared to earlier tubs) means the bottom of the front is lower, top is higher, or both, in relation to the rest of the car.
KevinP73 12-06-2007 12:45 PM
Example,
http://forums.pelicanparts.com/uploa...1196973941.jpg
http://forums.pelicanparts.com/uploa...1196973953.jpg
chancecasey 12-06-2007 12:49 PM
P.S. Nice "plug", Dave! ;)
chancecasey 12-06-2007 12:50 PM
I guess used Setrab STD172's are about as easy to find as hen's teeth, huh?
TRE Cup 12-06-2007 12:57 PM
aero issues are easily mitigated: get a carrera rubber lower lip and "hide" it on the back edge of the iroc underside. Or find some similar flanged rubber/ flexible plastic material to do the same. If you look at the underside of the ruf yellowbird front bumper, you will see what i mean. Add a splitter to the iroc too, and realize more downforce
a 964 has more "depth" than the 911; the upper bumper height is the same, its what hangs down that is different
chancecasey 12-06-2007 01:08 PM
wow - that is great info! Thanks Dave!
Bill Verburg 12-06-2007 01:53 PM
There were several different versions of lip used on real 3.8RSR
v1
http://forums.pelicanparts.com/uploa...1196977995.jpg
v2
http://forums.pelicanparts.com/uploa...1196978016.jpg
mjshira 12-06-2007 02:31 PM
man, that RSR 964 looks really awesome!
chancecasey 12-06-2007 02:40 PM
Yeah, my scruffier-than-Scruffy will not be worthy!
I did a little measuring - and the rear of the trunk floor pan is about 1 inch higher than the passenger compartment floor pan. The front of the trunk floor pan is about 1/2 inch higher than that, and 4 inches below the bottom of the IROC RSR bumper.
The lowest part of the steering rack assembly is about 1 inch lower than the passenger floor pan.
MyTurbo3.6 12-06-2007 02:52 PM
I have added a set of the factory widebody fenders and front bumper cover to a C4...it is a direct bolt on with no modifications. Additionaly, the factory front lip spoilers simply attach to the bumper cover undertrays with longer screws. If you are using factory parts, they should bolt right up without modification.
I also added two oil coolers behind the front bumper grill area...didn't need to modify the trunk area.
TRE Cup 12-06-2007 02:57 PM
Chance is discussing doing this to his 964, not making a 3.8 RSR look
http://forums.pelicanparts.com/uploa...1196981854.jpg
Bill Verburg 12-06-2007 03:00 PM
agreed and agreed, the only drawback to the dual factory coolers is cost.
The advantage is that they help aero effects a lot, the cooling air is dumped into a low pressure region just ahead and outboard of the front tires.
chancecasey 12-06-2007 03:09 PM
Maybe we are talking about 2 different bumpers? Here you can see the front bumper and that it is 12 inches top-to-bottom. The front trunk area, from the bottom of the fenders level to the bottom, is 13.5-14 inches, depending on what you define as the "bottom".
http://forums.pelicanparts.com/uploa...1196982504.jpg
http://forums.pelicanparts.com/uploa...1196982543.jpg
http://forums.pelicanparts.com/uploa...1196982584.jpg
Bill Verburg 12-06-2007 03:17 PM
Yes, you bumper is not correct for a 964.
see the 2 indents l&r thats for the cooler ducting
left
http://forums.pelicanparts.com/uploa...1196982925.jpg
right
http://forums.pelicanparts.com/uploa...1196982991.jpg
the bumper you have is for a 911 chassis w/ central mounted cooler, I suppose it can be adapted but that's a lot more work.
chancecasey 12-06-2007 03:24 PM
Yes, unfortunately I'm stuck with having to save money and slave away. I really don't have much of either to spare, but having to choose one, extra time is my only option. I got the bumper and fenders for $300 locally. The fenders fit like crap but but I finagled them on and they will do the job - same story with bumper. :rolleyes:
chancecasey 12-06-2007 03:26 PM
In case I haven't said so this is a low budget race car. Just want to get out there and need all the spare $$$ I can save for tires, entry fees, gas, etc etc etc.
sc 10-18-2013 03:49 PM
Bill, do you know who makes V2?
v1
v2
