-   -   Should there be foam between the inner and outer rear arches? (http://forums.pelicanparts.com/porsche-911-technical-forum/381114-should-there-foam-between-inner-outer-rear-arches.html)
Kroggers 12-06-2007 12:10 PM
Whilst undertaking my rear end tear-down (http://forums.pelicanparts.com/porsche-911-technical-forum/380731-car-killing-me.html), I was looking for rust at the top of the rear arches - where the outer and inner arches meet. Now I was expecting to find that they meet and were welded, but instead I find a gap filled with some sticky foam stuff which had been covered with paint. Is this done from the factory or some garage DIY crappy thing. I have it on both sides, so I am assuming it is original?
So, fists question - what is this stuff, and second question - what is the best way to get it all out, and last question - what do I replace it with???
Thank you for your time and advice!!
http://forums.pelicanparts.com/uploa...1196971830.jpg
Mr.Puff 12-06-2007 12:15 PM
Oh, it's sticky foam covered with paint.
Was the car ever repainted?
Kroggers 12-06-2007 01:12 PM
Yes, why?
Mr.Puff 12-06-2007 01:28 PM
Well, if it hadn't been then the foam would be original due to the paint... I guess.
SoCal70RSR 12-06-2007 01:33 PM
If I remember correctly from working on my car, it is original and I believe is there to protect it from build up of dirt and grime the rear tires would normally shoot up there.
I used expanding foam to seal it, not sure it's the best material to use but it's what I had on hand.
Mr.Puff 12-06-2007 01:35 PM
Maybe it also prevents vibration?
Kroggers 12-06-2007 02:19 PM
That is good to hear. If you had the same, then it is original. Now to find out how to clean it all out, and what to replace it with :confused:
Kroggers 12-06-2007 02:20 PM
Good thinking...
