911 will not idle when hot
:rolleyes:911 3.0 w/csi starts good, runs good, idles good cold.
will not idle when hot,stalls at idle |
wow, dont get so wordy! you havent even asked a question. are you looking for a starting point, suggestions, what?
so what have you checked? |
Im in the same boat here.. car starts cold and runs great..drives great with no problems what so ever..but after hot it stalls out at idle everytime.... it starts right away no problem..
anyone have any idea.. I had a post saved on my laptop to a cure for this but have since lost all that info.. oh its a 79 SC.. thanks Jay |
Could be your WUR out of spec, causing the mix to go too lean when warm. Check control pressures.
Could be a bad CDI box (do you have a Permatune?). They sometimes crap out when hot. |
thanks Paul..will have to check those out
Jay |
| All times are GMT -8. The time now is 01:39 PM. |
