mackgoo
Guest
Posts: n/a
Question Injection pump belt
How tight is your injection pump belt? My pump is all the way over and the belt still seems pretty loose.
Old 03-11-2001, 04:17 PM
john walker's workshop
Guest
Posts: n/a
Post
you may have worn drive wheels. generally with toothed belts, the adjustment is ok if you can twist belt 90 degrees reasonably easily at midpoint between wheels.
Old 03-11-2001, 04:41 PM
mackgoo
Guest
Posts: n/a
Smile
So I don't know if this is true, but if the case is I can turn the belt past 90 degrees then something is too warn? I'm pretty sure it's a new belt.
Old 03-12-2001, 05:44 AM
Jandrews
Guest
Posts: n/a
Post
Mack,
I have the same issue. My MFI belt seems looser than I would like it, but as far as I know it has never "jumped" time.
Plus, those pumps are really hard to adjust laterally when trying to tighten. Have you ever seen the turnbuckle type bolts on the RSR pumps? They attach to the top rear of the pump and then angle down to some point on the engine cover. I would like to have a setup like that, but have never seen the details in person.
John
73 911S
Old 03-12-2001, 07:47 AM
Guest
Posts: n/a
Post
you could turn the belt 360 if you twisted hard enough. 90 degrees with some resistance is acceptable.
Old 03-12-2001, 09:10 AM
mackgoo
Guest
Posts: n/a
Smile
I forget what the actual spec is, maybe 1/4 inch deflection at mid point. No one trys to achieve that?
Old 03-12-2001, 09:41 AM
