Mad Aussie Porsche nut
madpcar's Avatar
2.7 Weber set up ?
Can anyone give me weber setup info on the following 2 engine types :
1st is standard 74 2.7 S Stock CIS engine - I want to remove CIS and put a set of 40IDT's on
Venturi- 34 ?
Main jets- ?
idle jets- ?
air correction-?
emuls tubes-?
2nd Engine 2.7RS - Mahle p/c - S cams ,headers and a set of 40 IDT's.
Venturi-34 ?
Main jets- ?
idle jets- ?
air correction- ?
emuls tubes- ?
Also is it possible to us a CIS fuel pump with a regulator to reduce the pressure ?
Thanks for the help in advance !
Old 10-14-2007, 08:24 PM
10zz964's Avatar
Hi,
my car have 2.7 40IDA webber, the spec are s-cam, JE 9.5:1 ported head etc. This is what pmo recommended me.
STEET
34mm venturis
145 main jet
180 air
F3 emulsion tubes
60 idle jets
note: F3 tubes are NLA (no longer available) and that you usually have to run the F5.
For cars that spend more time on the track / high rpms:
36mm venturis
160 min jet
180 air
F5 emuls
60 idle
And the tall AVs (the cross-hairs looking part at the top of the carb, below the air horns)
also PMO sell the fuel pump regulator that work with cis fuel pump. how ever i use the fecet fuel pump.
hope this help
Old 10-14-2007, 10:13 PM
madpcar's Avatar
Thanks for that 10zz964. Anyone have any info on the stock CIS engine ?
Old 10-15-2007, 09:22 PM
Wer bremst verliert
JohnJL's Avatar
2nd Engine 2.7RS - Mahle p/c - RS cams, factory heat boxes and a set of 40 IDT's.
Venturi-34
Main jets- 145
idle jets- 57
air correction- 180
emuls tubes- F26
Spark is MSD and Crank optical pickup in standard dizzy.
2007 911 Turbo - Not a toy
1985 911 Cab - Wife's toy
1982 911 3.2 Indiash Rot Track Supercharged track toy
1978 911 3.0 Lichtbau toy "Gretchen"
1971 911 Targa S backroad toy
Old 10-15-2007, 09:48 PM
madpcar's Avatar
Thanks JohnJl - Can anyone help with the stock CIS engine ?
Old 10-16-2007, 03:29 PM
Hi, I have just fitted a STD 2.7 CIS Engine on Webers to my 914... I have read your thread and just wondered if you got sorted in the end and if so would mind sharing with jet and choke sizes etc with me?
I hope you don't and I look forward to hearing from you.
Many thanks
Andy
Old 12-11-2007, 06:01 AM
Venturi-34
Main jets- 145
idle jets- 57
air correction- 180
emuls tubes- F26
This setup works fine on a 2.7 stock CIS engine,...
I would have some 55 idle jets around, just in case.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 12-11-2007, 08:47 AM
