-   -   85 carrera blowing fuse...where's the backup light switch (http://forums.pelicanparts.com/porsche-911-technical-forum/381966-85-carrera-blowing-fuse-wheres-backup-light-switch.html)
85carrera 12-11-2007 02:56 PM
hey guys...is it true the backup light switch is near the fuel sending unit and "fanfare" for my 85 carrera? on the SC's i guess its on the transmission.
reason i'm asking is because the fuse keeps blowing. i could care less about not having backup lights, but the darn turn signals don't work when the fuse is blown. (it blows when i put the car in reverse)
thanks!
david
anyone know what the ohm reading _should_ be once i get that bad boy off?
john walker's workshop 12-11-2007 03:01 PM
it's on the nose of the transmission. testing should show open and closed.
85carrera 12-11-2007 03:34 PM
anyone know if i can get to this thru the access cover in the cabin? or is this a job for the roller/creeper?
david
john walker's workshop 12-11-2007 03:55 PM
ya gotta go under. one of the wires really would have to be contacting ground to blow a fuse. they usually just touch each other if they pull out of the switch inside their boot. no boot and hanging wires, then could be an issue. i wouldn't think that the switch itself would ever short to ground.
3.2 CAB 12-12-2007 04:57 PM
+1
911quest 12-12-2007 05:01 PM
I would think the problem is in the reverse light's
