Front vs. rear wheel sizing
Grady Clay made a recommendation in the ever-growing "Hester" thread to consider putting 6 x 15s in the front and 7 x 15s in the rear, with the same size tire, to slightly change the grip bias to the rear.
Thoughts?
1969 912/6 Coupe 1970 911 T Targa |
5.5's were originally designed for 185s and you could get 205s on the sixes. Everyone claims that 225s handle funny on sixes, I raced a few seasons and couldn't tell, but what do I know?
Anyway, handling balance is one thing, but remember that braking performance is a function of front tire traction mostly. I put the same question to my race mechanic, why not use 205 up front and 225 in the rear for better handling balance, but his answer was braking. Also rotating tires is easier when they are all the same size. For a street car I don't think it makes a huge difference.
'66 911 #304065 Irischgruen ‘96 993 Carrera 2 Polarsilber '81 R65 Ex-'71 911 PCA C-Stock Club Racer #806 (Sold 5/15/13) Ex-'88 Carrera (Sold 3/29/02) Ex-'91 Carrera 2 Cabriolet (Sold 8/20/04) Ex-'89 944 Turbo S (Sold 8/21/20) |
UFLYICU
An addition to Grady's assessment would be that not only does the wider wheel put more rubber on the ground, it tends to create a stiffer sidewall that is less flexible, which adds to the grip.
_______________________ Racer Rix Spec911 #5 prc-racing.com |
Non Compos Mentis
225s on a six?
I race my 944 on 7" wheels, and 225s are still pretty pinched. I'm not sure a 225 can perform properly on a six inch wheel. I tried putting my 225 rain tires on an old 912E I used to own, but they would rub badly with any compression of the rear suspension. Still, with 911s, adding tire to the rear to compensate for the rear-weight bias is a good thing. |
I hadn't thought about the ability to go to 205s on the 6s vs. 195s on the 5.5s. Makes this a more difficult decision. I'm guessing that i. there may be more effective ways to achieve the desired balance result (e.g., sway bars/sizing) and ii. For my street-driven cars the balance differences won't be that crucial.
I appreciate the input.
