Is it really just a bad plug wire?
Hey gang,
I had a sudden "Running like crap" situation with my 79SC.
Figured it had been awhile since I checked the plugs, so I pulled/replaced them. #3 cyl (I think, driver's side/front cyl) plug was wet with gas. Replaced everything, fired it up, and still the same thing. Thinking that was the problem cylinder, I pulled the plug wire from the cap, and it ran the same. Aha...
Did that wire just "go bad"? No other recent work, nothing changed.
Anything else to check for? JW said the wires were getting pretty old, so I'm really hoping that's all.
1. What's an easy wire test? Can I just do a continuity test, or maybe use the old plug touching the block to check for spark?
I'm hesitant to even crank it like that, thinking of unburned fuel giving my non-popoff airbox a nice wakeup call when combustion makes its triumphant return..
Cap/rotor pretty new. 196k.
Thanks for any tips!
Eric
1984 928s
5 speed
Old 12-09-2007, 02:12 PM
old man neri's Avatar
Get a volt meter and check the resistance across the wire. I forget what the spec is though. Move the wire around a bit when you are doing it to make sure it is consistent.
Old 12-09-2007, 02:17 PM
SC plug wires have around 1k to 3k ohm resistance depending on which ends you have. When they go bad the resistance jumps to 10k or more.
-Andy
Old 12-09-2007, 07:50 PM
jonbot's Avatar
What about using another one of the known good plug wires and see if that cylinder starts working again?
- Everything's easier once you get started. -
'95 993 C2
'73 911 Targa
'88 BMW M3
'84 Mercedes 190e 2.3 16v
Old 12-09-2007, 07:53 PM
3.2 CAB's Avatar
Also, a bad plug wire can show to be "open" with a test meter. There should be continuity, and it should be in the proper resistance range.
84' Steelslantnose Cab.
1953 Dodge B-4-B-108" 90,127 miles
1953 Dodge B-4-C-116" 58,146 miles
1954 Dodge C-1-B8-108" 241V8 POLY
1973 Roadrunner 440-SIX-PACK*
1986 F-250 Super Cab-460 V8 tow
Newest additions-
Matching numbers 1973 340 Road Runner!!
1948 Dodge B-1-F-152" 1-1/2 ton Dump body, 39,690 miles
others...
Old 12-10-2007, 09:20 AM
UnRegistered User
billybek's Avatar
The nice thing about testing plug wires is that you have 6 of them to compare the results from.
3 k ohm is what you should be looking for..
Bill K.
Old 12-10-2007, 07:18 PM
Ahh, screw it. I think those were all on their last leg, so I've got a set coming from our host.
Will post results...
Thanks for all your input.
1984 928s
5 speed
Old 12-10-2007, 08:46 PM
Let's hope it isn't a leaking fuel injector. Once a spark plug is wet, it doesn't like to fire. Don't get in the habit of diagnosing by credit card. It can become expensive.
Sherwood
Old 12-10-2007, 10:00 PM
Sherwood
I hear ya, but this is such a baseline item that I'd like to just address it and eliminate it as the cause. Besides, I haven't spent any money on her for months!
Wires show up today, will report back tonight.
1984 928s
5 speed
Old 12-11-2007, 06:07 AM
Solved. It was indeed a leaky injector, dribbling enough at idle to wet the plug and prevent firing.
No big deal, and the new red Clewitt wires are an early Christmas present!
Got to go to Aker's shop here in Seattle for the first time, what a lineup of 356s.
Charged way more than our host for an injector, but I had it 4 hours later, so...
1984 928s
5 speed
Old 12-17-2007, 11:16 AM
