ebenstein
Guest
Posts: n/a
Exclamation How much for a new trans? & whats best?
Hi all,
I just got the word from the shop, my trans is gone. I have a 1980SC engine and trans to match. I dont want to miss any oporitunity to "upgrade" to something better if posible but no nothing about transmisions and need some direction.
What should I expect to pay for a new trans?
What is a resonable price for install?
Is there anything else that should be replaced while its out? Clutch?
Thanks,
Kenneth
carwrecks.org
Old 03-13-2001, 10:33 PM
JackOlsen
Guest
Posts: n/a
Post
I'd talk to Gilbert at Vertex in Florida. They have rebuilt transaxles with a one-year warranty at very low prices. If it's possible, you might want to try to get a 72-75 915 with the lower 7:31 ring an pinion, although that would require some other changes to fit.
Jack Olsen
1973 911 T (3.6) sunroof coupe
jackolsen@mediaone.net
Old 03-13-2001, 11:02 PM
Early_S_Man
Guest
Posts: n/a
Red face
Kenneth,
Make that a '72-'74 915 with 7:31 ring & pinion! You would need a cable-driven speedo, unless you get the early 915 converted to the electronic sender, and that is $200-$300 higher!
Warren Hall
1973 911S Targa
Old 03-13-2001, 11:45 PM
JackOlsen
Guest
Posts: n/a
Smile
Whoops. 75? What was I thinking? Thanks, Warren!
Old 03-14-2001, 12:09 AM
VIPRKLR
Guest
Posts: n/a
Post
Are the main shafts in the early 915 tranny’s weaker than the 1980 and newer? Perhaps I am wrong about the date but I do believe there was a strength “upgrade” later in the 915s life.
Old 03-14-2001, 07:38 AM
john walker's workshop
Guest
Posts: n/a
Post
if a trans runs out of oil and galls all the gears, then it's considered "gone". otherwise they are generally rebuildable. a used trans may need to be rebuilt too. $500-$800 is average used price. if you buy a rebuilt unit they may not accept your bad core.
Old 03-14-2001, 09:13 AM
86ragtop
Guest
Posts: n/a
Post
Am very satisfied with my Vertex recon tranny, about 2,000 miles of highway driving and it is v. sweet (for a 915 )
rgds Ben
Old 03-14-2001, 02:44 PM
atr911
Guest
Posts: n/a
Post
I think that some of the suggestions mentioned here are just that, suggestions. I have never driven an early R&P tranny so I have no input. Check out how the driving is actually affected by going with the early trans. and then make the decision if that suits your style of driving.
If you are really looking for an UPgrade, look into the G50. You can either go with the short bellhousing from a place like Patrick Motorsports (add in Excellence) or do the work and convert to a standard G50. Either way is MUCH more expensive than a rebuild or used early tranny though. The improvments (I believe) would be extreme.
My two cents.
Adam Roseneck
1978 911SC 3.0
roseneck@cyberbeach.net
Old 03-14-2001, 04:33 PM
bevirt911
Guest
Posts: n/a
Post
Originally posted by ebenstein:
Hi all,
I am installing a 3.0 in my 1975 and have to use the same trans due to differnt half shaft and other pain in the -- stuff
Thanks,
Kenneth
carwrecks.org
Old 03-14-2001, 06:15 PM
