rwill57's Avatar
Replacement of Oil Cross Over Tubes - 3.0
Anyone ever replaced the oil cross over tubes on their engines. These are the collapsable type that look like a toilet paper tube.. and lock in the out position with a snap ring.. One is suppose to open them up and position them in the outlets while under the car... wow.. I am have a hard time.
Have you done? What tools have you used? Need tips.
thanks
Rich
Old 12-15-2007, 11:40 AM
not fun, especially drivers side.
What I did was coat the seals and tube with all kinds of lubricant, and wd 40. Set the tube close to the length that was needed.
Take a set of pliers or vise grips and put on the inner tube a screwdriver blade thickness away from the outer tube ridge with pressure. Be careful not to crush.
Take a large flat screwdriver and place between the outer tube ridge and the pliers and twist. The tube will extend.
Repeat until seated.
Move snap ring into place.
Old 12-15-2007, 11:51 AM
There are many, many threads on this...search for "oil return tubes"....
Here's one example ---> Oil Return Tubes-sucessful project
Look also at the Pelican Tech articles section---> http://www.pelicanparts.com/techarticles/911_oil_return_tube/911_oil_return_tube.htm
Do NOT use oil or WD-40.Use a silicone grease for the o-rings. WD-40 is especially worthless even as an oil. The WD stands for "Water-Displacement". A fluid to help displace water, like inside distributor caps. Totally worthless in this application.
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 12-15-2007, 11:53 AM
rwill57's Avatar
Great..thank you gentlemen. Just read something about "hose clamps" that I think will work for leverage and spreading the tubes..
Old 12-15-2007, 12:10 PM
