Thanks!!
Mike '86 911 coupe '85 BMW 535i '11 Cayenne |
wait, i thought that the fogs could be run without the headlights on by default...what year did they switch to doing this? both the 964 and the speedster allow the use of foglights without the headlights. don't know about the 87 since it doesn't have any fogs.
Website: The Motoring Enthusiast Work: Fantasy Junction Current P-cars: 1987 Carrera "'74 Carrera Look"-Bali Blue || 1989 Speedster-Guards Red || 1989 Carrera 4-Velvet Red || Grande project || and a bunch of other cars... |
On my car (and my understanding of how it came stock), the fog light switch was only active when lowbeams were on, but then turned off when highbeams were engaged. I believe it was(is) a law in some states that the fogs cannot be on by themselves or with high beams. But, since plenty of Canadian cars use below-the-bumper lights as daytime driving lights, I figured the fogs would work great for that.
Mike.. you're welcome! Technically, this is my first actual contribution to this board (small as it is) :-). Have lurked for a year and asked a few questions along the way. This community has been of immense help to me, so figured it was about time I gave a little back!
1984 911 Cabriolet - Destroyed :-( - Looking for the next one.. 1997 M3 sedan - Daily Driver 1988 Ferrari 328 GTS - Needs to be driven more |
I'm a loser, baby.
Why would this be made illegal?
1979 911 SC |
Ryan:
According to Oregon law, auxiliary and/or fog lights must be used like the high beam headlight system of your car. They must be dimmed or turned off within 500 feet of approaching an oncoming vehicle and 350 feet when following another vehicle. The color of auxiliary and/or fog lights is also regulated. Fog lights may be either white or amber (yellow). Rules prohibit other colors such as blue. The State just put out a memo about this, which noted that 'everyone does it' and 'manufacturers wire them to come on that way'. It also states that 'In normal visibility conditions, fog or auxiliary lights should be turned off.' Personally, I find it annoying when people drive about in broad daylight in clear conditions with them on- as on some vehicles they are very bright. The safety concern is that these lights focus your attention right off the hood- not out there where you should be looking. All that said, in some 911s you need all the light you can get- but I think the H4 upgrade is a safer alternative to fog lights, plus why give the cops another reason to pull you over? Cheers, Paul.
'85 Defender 90 V8 Station Wagon (mine), ‘16 Mini Cooper S Countryman All4, ‘79 Mini Moke Californian (hers). '83 SC Coupe SOLD '96 Carrera 4 Coupe SOLD '89 Carrera Targa SOLD Last edited by Paul K; 05-22-2008 at 12:27 PM.. |
My 89 will provide fog lights with parking lights (or maybe selective position of the parklight switch?)
Best,
Recording Engineer, Administrator and Entrepeneur Designer of Fine Studios, Tube Amplifier Guru 1989 Porsche 911 Carrera Coupe 25th Anniversary Special Edition Middle Georgia |
On my '88, if you pull out the headlight knob halfway, that turns on the orange lights, then you can turn on the fog lights.
Howard 2003 996tt 1997 911 Coupe Artic Silver (sold) 1988 Black 911 Coupe (gone but not forgetten) |
Thanks David!
When I get the time I will perform this little operation. Cheers, Kato |
My 87 will run the fog lights only if the running lights are on and the fog light switch is activated.
87 911 coupe "Katy" Summer Yellow Linen Mahogany interior 04 Pilot "The Pilot" |
Located the grey wire - which also has a much thicker yellow wire attached as well - on the bottom of fuse#17, dipped beam.
When you ran the grey wire back to fuse#1 did you have to solder on a piece of wire to get there or did you "pull out" the grey wire to get the length required? Thanks, Kato Last edited by KatoKato; 05-24-2008 at 08:54 AM.. |
Formerly known as Syzygy
Fogs must be turned off anytime you would dim your high beams otherwise you risk getting a "failure to dim lights" ticket. Ask me how I know this. -kevin
Kevin 1987 ROW coupe, Marine blue, with a couple extra goodies. The cars we love the best are the ones with human traits, warts and all. |
Cheers, Paul.
'85 Defender 90 V8 Station Wagon (mine), ‘16 Mini Cooper S Countryman All4, ‘79 Mini Moke Californian (hers). '83 SC Coupe SOLD '96 Carrera 4 Coupe SOLD '89 Carrera Targa SOLD |
Monkey Butt Forespin
Did my '84 this afternoon, 5 minutes total. I DID have a wire in the 2nd from front fuse (which looks REALLY tiny for a fuse, according to the back of the fuse box cover, that's the rear license plate light). Anyway, works as explained in the beginning, just enough wire to make this work without effort on mine, and I'll have no issues running my "driving lights". If I do, I'll get out of the car, point to how low they are to the ground & ask if the officer's worried about be blinding the Geico Gekko or something...
Fred Hurder Jr For Tech Questions: '84 911 Carrera Cabriolet (US) Weltmeister Chip, Fabspeed Euro Pre-Muffler, M&K 1-in / 1-out Muffler 22 ERP /29 Sander Hollow T-Bars, Bilstein HD Struts / Sport Shocks ERP Poly-Bronze Bearings (A-Arms & Spring Plates), Stock Swaybars Turbo Tie Rods, '92 C2 5-Spoke wheels w/ 1" adapters, Drilled Zimmermans Yes, I drive mine as much as possible. If it's >32° & sunny, I've got the top down.
Just completed the transformation ...
I tried to get at more of the grey wire by pulling it through from behind the fuse panel. Not much extra length came out so I had to do a patch to make it to fuse#1. The only problem I had is that red/blue wire at fuse#1 takes up almost all of the space available there. I had to flatten the grey wire and force the red/blue wire over top of it. I didn't get it in all of the way but enough so the screw makes full contact holding both firmly in place. I hope this won't be a problem. After driving around and turning the car off the lights go out automatically ... sweet! The only thing I did notice is when I turn the ignition to the start position (without starting), engage the fogs, and then take the key out, they stay on! I'm assuming there is some sort of built in delay in order to open/close the windows or something like that ? Last edited by KatoKato; 05-24-2008 at 11:45 AM.. |
-kevin
Hey Kato..
I too had to splice in an extention to the grey fog wire to get it to reach fuse #1. Regarding the fogs staying on, I saw another thread on here regarding folks able to use their power windows after the ignition was off, but before they opened the door. My electric windows work without the key in the ignition Seems might it might be normal operating in some years. In my car (84) the fogs and power windows shut off when ignition turns off.
Yeah, see my post above. Same 'sort of' problem. When I connected the thick gray wire to fuse #1, fog lights lit on even with no key in ignition. So do your fog lights turn off after a delay (engine off, key out), or when the door is opened? Weird. If problems persist with fogs staying on, use the power mirror fuse like I did---now mine works as planned. mike
Coming up to an intersection today, I noticed a car contemplating darting out from behind the stop sign. I gave 'em a flash of the headlights...damned if they STILL didn't pull out in front of me! NOW, I may wire the fogs into the flash circuit for some additional lumens when issuing a warning....... ! (don't think it will help the idiots...)
...back to our regularly scheduled programming. KatoKato: did you get it figured out? (this funky delay...?) Best,
Haven't thoroughly checked this yet. I will get to it. I've also been thinking about running the windows off of fuse #2 (My A/C is removed and I have my seats set to the lowest position) so I can properly connect the grey wire to fuse #1. As I stated previously it's jammed in there and I don't like it like that. |
