Member 911 Anonymous
Recent pics with converted running lights:
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
Followed Wil's directions above...only after I went through a bunch of other options. I have an '84 Carrera, so if anyone has the same year, Wil's approach will work. Now just to clarify some areas as to where exactly the fuses are and which wires to move, I'll quote from the Bentley manual, page 971-14 Table C. The Yellow/Gray wire is located in the #2 fuse block and is in position #4. I had both yellow and gray wires in there...remember, it's at the bottom of the fuse in position #4. Then insert the gray wire (only) into the #7 position of the #2 fuse block, I had a blue and white wire in mine. I also changed out the 5amp fuse to an 8amp fuse in fuse position #7. Tada! Driving lights (no fog in Hawaii) will turn on with city lights and parking lights on...or anytime I want. Thanks Wil, I only wish I read your comment sooner than later! Oh...and like Wil said, don't blame me for any fires....you do this on your own account.
Woody Slow n Fast 1984 Guards Red 911 Carrera |
Formerly known as Syzygy
Woody, you have driving lights and not fogs? Where did you get the lenses as pretty much everyone else has fogs? That's on your Carrera, right?
Kevin 1987 ROW coupe, Marine blue, with a couple extra goodies. The cars we love the best are the ones with human traits, warts and all. Last edited by Canada Kev; 12-03-2011 at 10:41 PM.. |
It's the OEM lights (fog lights) that come with the car however, because the lens are clear and not amber/yellow, they enhance the driving ability at night and would be detrimental in fog. Hence I call them "driving" lights and not fog lights. Sorry if I caused any confusion...I just can't see clear lens used while driving in fog.
Just a note,
If you do plan to convert the Fogs to DLR's then you should consider getting the 35 watt H3's. I found the 55 watt ones will melt the plastic housing. Mine pictured abpve are 35 watts motor cycle H3 bulbs. CPI 35-watt H3 motorcycle bulb
Woody, fogs aren't fogs because of the color, it's the beam pattern. If you look closely, you will notice the vertical flutes in the lens that will direct the light in a low, side beam pattern. They may actually harm longer distance vision at night. That's because they illuminate the close up fore-ground areas, over stimulating your eyes and reducing distance vision.
Clear lenses are not bad in fog. The amber does reduce the intensity of the light which may be a bit better for some in heavy fog. If that is often an issue, using lower wattage bulbs as Draco suggests will fix that up. In fact, I plan to pick up a couple of the 35 watters just for that reason. Thanks for the link on those bulbs, Draco.
Kevin 1987 ROW coupe, Marine blue, with a couple extra goodies. The cars we love the best are the ones with human traits, warts and all. |
Your Welcome!
But in all seriousness, even if you do not use it as a DLR, guys with the fog light system one should really take a closer look at their fog light housing with those 55 watt bulbs, not a pretty site.
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC Last edited by DRACO A5OG; 12-05-2011 at 09:15 PM.. |
I guess I should mount some lights on my hood...then I can call them driving lights...and do some Porsche Rally Racing... I stand corrected...learn something everyday! I now have independent Fog lights!
Yeah! A bunch of big friggin' rally lights! LOL
I really wish that someone made a driving light lens for the fogs, but they're kinda low for that purpose, I suppose. Having good headlights, relays and not all pitted up lenses there make a world of difference.
Continued reading this thread and saw Gerry's post here. Thought I'd try moving the grey wire to fuse #10 as indicated in Gerry's thread and it worked. So now I have DRLs when the car is on, by leaving the fog light switch in the on position. Thanks! Lex |
I think you can get away without DRLs up to '88? Maybe it's 1989... Is your car a ROW?
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Fog Lights.
1986 911 Targa. Per Road and Track magazine: Only in L.A.: In the window of a bar in Hermosa Beach, California. "Happy Hour prices during all car chases." |
The car is a US car, purchased in Oct '11. Lex |
Lex indicated that due to living in Canada he needed DRLs, not necessarily desired them. They were mandated here between '86 and '89 depending on the vehicle type. While many (especially in the US) really don't like DRLs, I find them a benefit. Whenever I'm driving on the highway, I always turn some lights on whether fog of headlights. However, I rarely use them in town except when the lighting is degraded. The DRLs are really for the people that can't seem to turn the things on at dusk, night or in the rain. They even help being visible when you're coming out of the sun when it's low on the horizon. Almost everything on the road here has them and it does really make a difference, regardless of what the naysayers say. You're preaching to the choir, brother.
Kevin 1987 ROW coupe, Marine blue, with a couple extra goodies. The cars we love the best are the ones with human traits, warts and all. Last edited by Canada Kev; 05-07-2012 at 07:08 PM.. |
So it's really a Nova Scotia thing and not a Canada thing for you, then. Gotcha. When did NS change the law to make that the rule? When I lived there, it wasn't any more than the national code regarding DRLs. Mind you, that was about eight years ago. And with the required annual inspections, they'll probably find it if it's not there. Just hope one of the techs doesn't notice that your fog light switch is in the on position. If that's the case, then you might just have to wire the fog relay trigger lead to a hot on run connection. That way your fogs will be on whenever the ignition is in the second position.
Just checked this out as I hadn't heard anything about this. Yep, as of April of 2009, stiff fines for no lights. Something to keep in mind for all of you that might vacation to this beautiful area of Canada.
The province will take another step to improve road safety when all vehicles on Nova Scotia roads will be required to use daytime running lights starting Monday, April 13. "We know that daytime running lights have been shown to reduce daytime injury crashes by three to 10 per cent," said Transportation and Infrastructure Renewal Minister Brooke Taylor. "This law will help ensure everyone on our roads will benefit from the added safety that daytime running lights provide." Passed in the fall session of the legislature, the new law will require drivers to use low-beam headlights during daylight hours if they do not have automatic daytime running lights. While daytime running lights are mandatory on all vehicles manufactured and sold in Canada after 1990, there are a number of vehicles on Nova Scotia's roads that predate the change. Antique cars are exempt. The fines, including court costs, will range from $164.50 for the first offence to $337 for the third and subsequent offences. The legislation is part of the province's legislative, enforcement and awareness initiatives to improve road safety. The initiatives include a ban on hand-held cellphones, stronger and expanded penalties for street racing, legislation and funding to improve crosswalk safety, and an integrated impaired driving enforcement unit. Learn something new every day...
Kevin 1987 ROW coupe, Marine blue, with a couple extra goodies. The cars we love the best are the ones with human traits, warts and all. Last edited by Canada Kev; 05-07-2012 at 07:09 PM.. |
OK, resurrecting this, as referenced from the current "LED lights" thread: I want to do this mod (use front fogs as DRLs), but my '87 seems to be different than the '84-'86s referenced here: the gray wire in the front (fuse #20) shows to be for the license plate light in my car, according to the schematic I have. Has anyone done this for an '87?? Which wire do I move? TIA.
'87 Carrera (3.4L) w/Turbo, full-bay IC; front bumper aux oil cooler, etc. '07 Boxter |
I tried #11 fuse and #5, but the fogs would still only work with the low beams on. Thanks, joe
jtp911 |
Here's the owner's manual diagram of the fuses on a 78.
jtp911 |
